No Ignition Lights Or Fuel Pump Prime On 95 Spi
2 replies to this topic
#1 Richard Rowley
Richard Rowley
    Starting My Mini Up
  • 2 posts
Posted 12 January 2020 - 11:42 AM
Morning mini forum
The car
95 SPI with specialist components throttle bodies and Delta 400 ECU
Problem
Just rebuilt the engine and dropped it back in and there is no ignition light and the fuel pump is not priming
Taking the engine out and putting back in obviously disturbs the wiring, but all the plugs have gone back together in teh corerct place
I've checked the earth straps on the engine and in the boot and tried a jump lead straight from the battery to teh engine to check, but no joy
I've checked all the fuses in the fuse box above the clutch master cylinder and they are ok. I've had a visual check behind the fuse box and can't see anything obvious
Battery is charged and the wipers and hazards work when i turn the ignition to the fist position, but no fuel pump priming and no lights on the dash nor indicators
Everything worked fine before the engine came out (apart from the engine !), so not sure what's changed
The large relay on the servo has some corrosion on the PCB and i've been meaning to change it, but it's been like that for 3 years, so not sure that is the issue
Anything obvious for me to check before i have to bring in a specialist?
regards
Rich
#2 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 12 January 2020 - 02:46 PM
Do the wipers and hazards work when you turn the ignition to the second position?
If not, that might be your problem.
Try disconnecting the ignition key switch and checking it, first.
Spraying some ACF50 into it and working it repeatedly might (just might) revive it.
#3 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 13 January 2020 - 11:23 AM
Check fuse 8
