Hello, been a while since I last posted.
Got to the front of mini now and have a slight issue. I need to put on half inner wings and also replace the crossmember where the clutch cylinder etc mount, which would you do first with regards to things lining up with shock mounts. I think if I do crossmember the holes for shock mount in the inner wing will disappear because of corrosion, opposite way I not sure how bad the ends of crossmember are when drilling out for inner wings.
All suggestions will be helpful thanks
Ian
Where To Start
venkman
, Jan 12 2020 04:34 PM
No replies to this topic
