Duct For Air Hose
13 replies to this topic
#1 Mayfair'93
Mayfair'93
  • 29 posts
Posted 12 January 2020 - 09:55 PM
Hello,
Does anyone know where I can find a L/H duct to be fitted behind the grille for a non-injection Mini and the accompanying air hose?
It is to take fresh air through to the passenger side vent. At the moment I just have hot air blowing in from the engine!
The usual website/shops don't seem to stock them...
Thanks,
E.
#2 MiddletoM
MiddletoM
  • Just Joined
  • 60 posts
Posted 12 January 2020 - 11:10 PM
The hose:
http://www.somerford...roducts_id=6286
All the parts for the vent system:
http://www.somerford...age=page&id=104
Edited by MiddletoM, 12 January 2020 - 11:14 PM.
#3 Mayfair'93
Mayfair'93
  • 29 posts
Posted 13 January 2020 - 11:08 AM
Thanks MiddletoM.
I contacted Somerford and they don't stock the duct either. They say it is no longer available/obsolete.
Any other leads? Or perhaps a workaround?
Thanks,
E
#4 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 13 January 2020 - 12:11 PM
Try car builder solutions for the hose/pipe, and possibly the other parts needed
#5 Chris1275gt
Chris1275gt
  • 1,054 posts
Posted 13 January 2020 - 12:31 PM
You can get all sizes of ducting flexible or rigid plastic on eBay.
#6 andyapanel
andyapanel
  • 651 posts
Posted 13 January 2020 - 12:38 PM
I bought mine (pre-loved) from a trader at Himley.
Try mini dismantlers.
Good luck
#7 jeffster06
jeffster06
  • 113 posts
Posted 13 January 2020 - 01:23 PM
I needed a piece of duct for the driver side and found some corrugated drain pipe at a hardware store that worked well. Perhaps you could find something that is meant for a different purpose that will work for you?
#8 IronmanG
IronmanG
  • 1,363 posts
  • Local Club: Box hill. Lsmoc member
Posted 13 January 2020 - 06:09 PM
I used to buy all sorts of hoses from RS at my old job. Whatever size you could think. Prices were not so awesome though
#9 leepol83
leepol83
  • 1,744 posts
Posted 26 January 2020 - 07:41 PM
Sorry to hijack but do they still put the foam inside these pipes ? I’ve got a driver side one fitted with no foam in it it’s the one from the air scoop to the heater box
#10 leepol83
leepol83
  • 1,744 posts
Posted 26 January 2020 - 07:43 PM
eBay item number 202886249942
#11 Mayfair'93
Mayfair'93
  • 29 posts
Posted 27 January 2020 - 08:18 PM
Thanks for all your help!
I managed to find an intake on ebay and a hose (with foam) at Bingley Hall so all sorted.
#12 leepol83
leepol83
  • 1,744 posts
Posted 27 January 2020 - 08:33 PM
Nice one !
Don’t suppose you could measure the thickness of the foam could you ?
#13 Mayfair'93
Mayfair'93
  • 29 posts
Posted 28 January 2020 - 09:21 AM
I make it 5mm. Hope that helps!
#14 leepol83
leepol83
  • 1,744 posts
Posted 28 January 2020 - 12:14 PM
[quote name="Mayfair'93" post="3631545" timestamp="1580203286"]
I make it 5mm. Hope that helps![/quote
Great thank you mate
