Toe-Board Hole :(
3 replies to this topic
#1 finch661
finch661
  • 2,340 posts
Posted 14 January 2020 - 04:53 PM
Hello all.  My mini sadly failed its mot, due to a hole in the toe board (glad they found it to be honest).  I have removed the carpets, and poked with a screwdriver.
It looks a lot worse in the photo, the floor pan is solid, as it the other side.  the rust is impacting on the subframe mount.  My initial plan was to cut out the rot, replace with 1mm steel, then weld a 2mm plate for the subframe out (and the usual seam sealer/paint/underseal). Any other thoughts.  it looks like it has been repaired in the past (badly).  I am not overly keen to replace the whole panel :(
thanks
Rich
Edited by finch661, 14 January 2020 - 04:53 PM.
#2 sc-em
sc-em
  • 214 posts
Posted 14 January 2020 - 07:46 PM
Clean back to bare metal just to be sure. I started with a few small holes and the rust worm just spread.
#3 finch661
finch661
  • 2,340 posts
Posted 16 January 2020 - 01:00 PM
Will do mate, hopefully it hasnt spread too much
#4 sc-em
sc-em
  • 214 posts
Posted 16 January 2020 - 07:51 PM
Not this bad hopefully. :D
