It Started As An Intellectual Exercise
109 replies to this topic
#1 Trog
Trog
  • Just Joined
  • 91 posts
Posted 17 January 2020 - 11:01 PM
So 18 months ago I started designing an 8 port as a bit of fun...
(Though I have been thinking about it for a lot longer http://www.theminifo...og#entry1602197)
Things sort of gained momentum:
Attached File  20200118_093828.jpg   32.67K   31 downloads
Attached File  20200118_093841.jpg   30.71K   18 downloads
Attached File  20200118_093928.jpg   35.59K   12 downloads
Attached File  20200118_093910.jpg   31.98K   11 downloads
Attached File  20200118_094035.jpg   36.6K   17 downloads
Attached File  20200118_094020.jpg   32.26K   18 downloads
More pictures to follow if you are interested!!!
#2 Steve220
Steve220
  • 5,144 posts
  • Local Club: BMC
Posted 17 January 2020 - 11:05 PM
Moist!
More info please!!!!
#3 Steve220
Steve220
  • 5,144 posts
  • Local Club: BMC
Posted 17 January 2020 - 11:06 PM
Where's the thermostat housing?
#4 KTS
KTS
  • 2,490 posts
Posted 17 January 2020 - 11:29 PM
Crikey - that's some end result for a bit of fun !!
#5 Trog
Trog
  • Just Joined
  • 91 posts
Posted 17 January 2020 - 11:50 PM
Thermostat housing etc.:
Attached File  20200118_103920.jpg   40.5K   21 downloads
Attached File  20200118_103927.jpg   41.93K   17 downloads
Attached File  20200118_103935.jpg   40.52K   12 downloads
#6 Tupers
Tupers
  • 4,176 posts
Posted 18 January 2020 - 12:43 AM
Top work, it reminds me of the old Weslake heads than ran in inlet tract directly onto the top of the valves.
Are those fuel injector bosses that you’ve got cast into each port?
#7 Spider
  • 15,871 posts
Posted 18 January 2020 - 04:31 AM
So you've designed it, had it cast and then machined it ?
WHOLLY COW !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mate, I really doff my hat here - big time. This is one very serious effort.
I make a few bits and pieces, so I have an idea just what it takes, but this blows anything I've done well out of the water.
Keen to see how you go with it from here - good or otherwise.
I'm impressed too with your design ingenuity with the Thermostat Housing and the ancillary bracket at the other end.
Just blown away with this !
#8 Trog
Trog
  • Just Joined
  • 91 posts
Posted 18 January 2020 - 04:59 AM
Thanks! Yes the Weslake style down draft ports were part of my original design brief... Though with the injector bosses (Right again) I only got 30 degrees down draft, I suspect the Weslake was a bit more.
#9 Trog
Trog
  • Just Joined
  • 91 posts
Posted 18 January 2020 - 05:04 AM
Thanks, yes a lot of work, and a lot of sleepless nights! But have I learnt a lot! which was part of the aims of this project. There were quite a few drivers for the thermostat housing, Not sure how much detail to go into without being accused of being a "Noob"!
If folks want a breakdown of the design and development I can but I often get accused of going on...
#10 Spider
  • 15,871 posts
Posted 18 January 2020 - 09:35 AM
Mate - go on all you like. I'll listen. If others don't like it, they can swap channels. This is your stage here, make the most of it ;D
I 10000% understand and respect the 'learnt a lot' bit, I really do.
I can see there were some 'drivers' as you put them for certain aspects of it here and would be happy to learn from a pro like you.
#11 pdaykin
pdaykin
  • 587 posts
Posted 18 January 2020 - 11:47 AM
I would love to hear more. Very impressive.
#12 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 18 January 2020 - 12:18 PM
Wow, some work there!
#13 MacGyver
MacGyver
  • 1,028 posts
Posted 18 January 2020 - 12:20 PM
That would suit my engine nicely. ?
Very impressed!
#14 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 18 January 2020 - 12:26 PM
Great work, I'd be interested in seeing more of how you've done it. Did you carry out the machining work yourself?
#15 Exminiman
Exminiman
    Starting My Mini Up
  • 4 posts
Posted 18 January 2020 - 01:04 PM
Have you had a  chance to see how it flows yet,?
Brilliant work though, sure many, inc me , have daydreamed a solution, very few get them finished, or even started though :highfive:
Edited by Exminiman, 18 January 2020 - 01:05 PM.
