Let us go through the math together. (it doesn't work perfectly)
70.6mm =.............................................................Cooper S bore
35.3mm X 35.3mm = 1,246.09 = .........................The bore radius squared
times pi = 3,1416 = 3,914.7163........................The area of the bore
times 68.26 = the stroke, gives 267.21853cc = ...The volume of one cylinder
times 4 = 1068.8741cc, should be the size of a....1,071ccCooper S engine, but as I say, it doesn't seem to work out correctly.
For some reason, this works out at 2.126cc too small.
Your measured compression height of 37.15mm is .97mm less than my recollection of the 38.12 1071cc Cooper S compression height, .....so,......let us see what happens if we add .97mm to the 1071 cc Cooper S stroke which then becomes 69.23mm.
times 69.23mm = the new stroke, gives 271.0158cc = the volume of one cylinder
times four = 1,084.0632cc, which could be the theoretical original capacity of your original engine, depending on how accurately you managed to measure the compression height, but unfortunately doesn't come out any where near the South African "1100", which (someone in S.A. will correct me) is 1098cc; in which case it is 14cc too small.
Now let us add .020" (.51mm) to the rebored engine and recalculate.
70.81mm..................................................................New bore size
35.405mm X 35.405mm = 1,2535.514 =..................The bore radius squared
times pi = 3.1416 = 3,938.0395...............................The area of the bore
times 69.23mm = "the stroke" gives 272.63047cc.=....The volume of one cylinder
times four = 1,090.5218cc, (an additional 6.5cc) which could be the theoretical capacity, depending on how accurately you managed to measure the compression height.
P.S. I have found a note in my workshop manual, which probably indicates that the South Africa 1098 engine has a stroke of 69.85mm.
Edited by DeadSquare, 21 January 2020 - 04:49 PM.
