Vmaxscart Supercharger Graph
20 replies to this topic
#16 phillrulz
phillrulz
  • 617 posts
Posted 23 January 2020 - 09:55 PM
I’m really tempted by this kit for my 998, especially when you read on his Facebook account, 90bhp from a 998, it’s the concerns about charge temperatures that stops me, read differing opinions on the effectiveness of the charge cooler.
 I doubt ill ever drill mine for a boost guage, but if i go ill get a PT100 RTD in there since they fit in 6mm push fit fittings
#17 bluedragon
bluedragon
  • 292 posts
Posted 24 January 2020 - 04:09 AM
A true chargecooler (tube-type like a typical radiator) is very questionable in a VMAX SCART type setup. They run the supercharger wet (fuel is added to air ahead of the supercharger instead of after it.)
If you installed a traditional type chargecooler, it would be filled with air and fuel mixture when running. If there's a backfire, there could be a lot more than just a popping sound...
Dave
#18 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 25 January 2020 - 10:59 AM
to be honest - the weber kit runs fine. You just need an aux electric fan off an spi and cold air supply to air filter. Heat is not much of an issue
#19 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 January 2020 - 11:01 AM
Dave
with this kit you can't fit an intercooler as its suck through. So worring about air/fuel mixture in an intercooler is a moot point
Edited by HUBBA.HUBBA, 25 January 2020 - 11:02 AM.
#20 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 January 2020 - 11:04 AM
Just do it. Bang for buck it's hard to beat.
#21 phillrulz
phillrulz
  • 617 posts
Posted 25 January 2020 - 02:16 PM
I stand corrected replacing speedo cable today found a 4mm push fit coming from the rear under one of the I guess you’d call rotors , will get a gauge on it and have a look at boost pressures.
