1992 Mayfair, no haynes manual to hand, they are both at my dads so some help would be appreciated.
Before i start fault finding i just wondered if anyone has ever had this before?
Before ignition is engaged, no key in the car and you can apply the indicators (i know this shouldnt happen until 2nd click on the key)
Turn the car on and it starts up fine, nothing out of the ordinary until you go to turn the car off. it just keeps running. I have a digital voltmeter as part of my dash setup and when you turn the key off it goes from 13v (its low as i need to get around to replacing the fan belt) to 11.8v or there abouts.
Am i right in guessing that when the key is in the 'off' position, it takes away the 12v feed to the '+' of the ignition coil?
thanks guys
