Rear Valance
Posted 21 January 2020 - 12:14 PM
Posted 21 January 2020 - 01:30 PM
I can't see that being a problem as it isn't structural. i can remember seeing minis driving around with out them on in the past.
Posted 21 January 2020 - 02:10 PM
Posted 21 January 2020 - 02:51 PM
Would a modern MOT tester even know how it was originally fitted?
Posted 21 January 2020 - 03:14 PM
Posted 21 January 2020 - 03:21 PM
Haha probably not.
Make it look professional and you will fox them forever!
Posted 21 January 2020 - 06:52 PM
Posted 21 January 2020 - 07:33 PM
Posted 21 January 2020 - 09:56 PM
Posted 22 January 2020 - 01:02 AM
It’s only the cavities on each and that you really need to worrying about and those are easily waxoiled from the inside of the boot if you drill a small hole and pop a plug in afterwards.
Posted 22 January 2020 - 12:43 PM
Is there no rust on the other two panels there?
When I did this job, I also had to replace part of the boot floor and the base of the rear panel as well.
As mentioned, the new panelwork lasts a long time as long as you keep waxoyling the area.
Good luck whichever course you go down
Posted 22 January 2020 - 01:19 PM
my personal thought is that if it isnt spot welded and only held with the 3 bumper bolts then you have a bigger gaps to collect water and have movement/rub etc. however a different option would be you glue/bond a fibreglass one on instead. then no rust.
