Random, Brief Loss Of Power While Driving
Posted 23 January 2020 - 08:03 AM
I did have the rear demister, headlights and fan on - could it be that my alternator couldn’t cope with the load and/or is going bad?
Having those things on is completely normal for me whilst driving to work at this time of year - the car has never done that before. Just odd that it seemed to give up briefly, then went back to normal.
Thoughts?
Posted 23 January 2020 - 08:12 AM
I'd start by checking the battery, solenoid, ignition coil and engine to body earth strap connections for condition and security.
Posted 23 January 2020 - 09:41 AM
So I had a bit of a weird one today (the car is an ‘81 HL Auto) - while on a dual carriageway, I lost power (no throttle response) and the red ignition light came on. Lasted for a few seconds then went back to normal.
Thoughts?
Did the headlamps go dim ?
Posted 23 January 2020 - 12:29 PM
Thoughts?
I'll give the battery/solenoid/ignition/earth a check over later, just to make sure it's all good.
I don't think the headlamps went dim at the time, though now you mention it, when parked, the headlamps are noticeably dimmer. As soon as I press the accelerator to pull away, the headlights are definitely brighter.
Posted 23 January 2020 - 12:47 PM
I had a similar issue recently when I swapped to a center speedo, didn't have an ignition light on but noticed my tach was bouncing all over and not reading correctly. Occasionally the car would sputter and feel funny as well. I rewired the tach twice and the problem still persisted, it ended up being a loose connector on my ignition coil, it still clicked when connected but had a bunch of wiggle to it, I swapped the connector and all has been well since.
