Code Reader Communication Issue
Best Answer kommander , 05 February 2020 - 11:57 AM
So I did a continuity test on the cable, pin to pin and there's a broken connection. Go to the full post
7 replies to this topic
#1 kommander
kommander
  • 210 posts
Posted 31 January 2020 - 01:48 PM
SP ACR 2 unable to establish communication. Tried it on 3 SPi minis with the same result. There's no MPi mini in my area to rule out whether it's the tool or cable. Has anyone experienced this?
Also, how robust are these readers? My guess is a faulty cable.
Edited by kommander, 31 January 2020 - 04:19 PM.
#2 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 31 January 2020 - 03:31 PM
I have the same problem, worked for a few years and now it won't. Tried it on three SPi's with no luck. still reads MPi with other lead.
#3 Squipper
Squipper
  • 71 posts
Posted 31 January 2020 - 04:48 PM
Hi
Are you using right Code Pod? As there are 4 different Code Pods?
#4 FlyingScot
FlyingScot
  • 2,676 posts
Posted 31 January 2020 - 06:43 PM
Which Pod and which cable ? Is the cable and official one or home made/EBay one?
They are usually very robust bearing in mind if it’s an ACR2 it’s probably 20 years old
FS
#5 kommander
kommander
  • 210 posts
Posted 01 February 2020 - 05:23 AM
The cable is an official harness 30211600 with a version 3 pod.
The scan tool has worked flawlessly on many occasions.
It powers on but unable to establish communications.
#6 kommander
kommander
  • 210 posts
Posted 05 February 2020 - 11:57 AM   Best Answer
#7 viz139
viz139
  • 727 posts
Posted 06 February 2020 - 10:32 PM
Checked my cable and its ok. I'm using Pod 4.
I tried memsgauge  o mine but that didn't connect either.
#8 FlyingScot
FlyingScot
  • 2,676 posts
Posted 10 February 2020 - 11:41 PM
Test for continuity from the white plug back to the ECU, could be a break there
FS
