Ballast Coil
7 replies to this topic
#1 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 01 February 2020 - 06:39 PM
im currently running a ballast coil without a 1.5 ohm ballast resistor , basically got the car two months ago and still sorting through the wiring etc, it runs a 1275 metro lump   using the lumenition  mega spark 3  ballast coil do I need the ballast resistor that is supposed to be with this coil  see enclosed photos ,theres no stamp on the dizzy either not that I can see just a few numbers so not sure what dizzy its running  6VXZy1b.jpg
Edited by mercenary62, 01 February 2020 - 06:41 PM.
#2 mercenary62
mercenary62
  • 359 posts
Posted 01 February 2020 - 06:41 PM
zy
#3 mercenary62
mercenary62
  • 359 posts
Posted 01 February 2020 - 06:43 PM
gonna clean the engine to see if I can find out what the dizzy is exactly ,no idea just by looking at it
#4 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 02 February 2020 - 11:17 AM
That's a late electronic type dizzy, looks to be a 65D.
I haven't used that coil before, so cant comment on the compatibility
#5 Ethel
  • 26,820 posts
Posted 02 February 2020 - 11:40 AM
The correct coil for a 65 is GCL143, but there was a topic not long back where some were saying they were using ballast coils successfully.
Your coil should be 1.5ohms & a GCL143 is 1ohm, so I don't think you'd need to add more resistance.
#6 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 02 February 2020 - 07:47 PM
The GCL143 is an old Unipart part number but can still be used for cross reference.
#7 mini13
mini13
  • 3,811 posts
Posted 02 February 2020 - 08:25 PM
running a balast coil without the balast is likely to cause the coil to **** itself,  i had this on a mini where it got through a coil about once a year, it was fie once i put the right coil on.
#8 mercenary62
mercenary62
  • 359 posts
Posted 02 February 2020 - 09:27 PM
cheers for the advise
