Final Drive Interchangable?
5 replies to this topic
#1 luismx123
luismx123
  • 525 posts
Posted 02 February 2020 - 01:12 PM
hey all
I got my hands on a 3.44 FD pre A+ crownwheel and want to install it on my 1990 A+ gearbox with a minispares x-pin diff.
Do i need to get a pre A+ pinion too or does it fit with an A+ pinion, or will a pre A+ setup (crown and pinion) not work at all on my new X-pin diff and A+ gearbox?
thanks
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 02 February 2020 - 02:31 PM
hey all
thanks
YES. "Crown wheel & pinion" means a matched pair, 'crown wheels and pinions' is generally taken to mean assorted cogs.
You need a matching pinion to go with your recently acquired crown wheel, what ever set up you have, X pin or bog standard.
Edited by DeadSquare, 02 February 2020 - 02:45 PM.
#3 luismx123
luismx123
  • 525 posts
Posted 02 February 2020 - 02:41 PM
hey all
thanks
YES.
yes to what?
#4 Rorf
Rorf
  • 866 posts
Posted 02 February 2020 - 03:50 PM
I think he answered your question O_O
#5 Spider
  • 15,841 posts
Posted 02 February 2020 - 04:48 PM
The Helix Angle and Tooth profiles were different between A and A+ in final Drive Gears, so, YES you will need an 'A' type Pinion.
The 'A' type were plain where as the A+ had 'line' ground in across the tips of the teeth to make them easier to distinguish.
#6 luismx123
luismx123
  • 525 posts
Posted 02 February 2020 - 05:02 PM
perfect thank you. the answer I was looking for!
