Verto Cluch Really Close To The Floor
3 replies to this topic
#1 minicooperr
minicooperr
  • 277 posts
Posted 02 February 2020 - 03:35 PM
I have an issue with my Verto clutch, it is so close to the floor and hardly disengaging.
I have replaced from the master to slave with a one piece braided line, the slave itself, the pushrod, the plunger and release bearing as well as the clutch arm but yet still a very low clutch
Do I just replace the clutch and pressure plate?
#2 minicooperr
minicooperr
  • 277 posts
Posted 02 February 2020 - 04:29 PM
I have just been measure my movement on the clutch fork and its just a bit less than 3/4 inch so this should indicate a mechanical problem?
Edited by minicooperr, 02 February 2020 - 04:32 PM.
#3 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 02 February 2020 - 07:52 PM
It will be ok, when I changed mine and set the throw out nut to 6.5mm.
#4 minicooperr
minicooperr
  • 277 posts
Posted 02 February 2020 - 08:32 PM
Not sure quite what you’re saying here, throw out nuts I have taken off, don’t make a difference to my problem at the moment, I will refit when the cars back together for the time being I think I am going to replace my clutch as I think it’s a pressure plate issue
