Clutch Removal
12 replies to this topic
#1 cristiano1968
cristiano1968
  • 444 posts
Posted 02 February 2020 - 08:55 PM
Hi
I'm removing my clutch .
(Doing an engine rebuild).
Can you guys refresh my memory on the position to take clutch of without the primary gear ring falling and blocking .
I have the engine at TDC .
The slots where the bolt is are vertical
Can I take it off like this or is it safer horizontal
Or can I take the bolt of as it is in the pic with the slots vertical then turn crank so crank slots are horizontal?
#2 phillrulz
phillrulz
  • 617 posts
Posted 02 February 2020 - 09:29 PM
I didnt know there was any special process about taking the clutch off, i jammed the flywheel,Took out the big bolt washer and thick like washer/drift  out,  puller into the flywheel and crank in it till the flywheel clutch assembelly explodes off.
#3 nicklouse
  • 19,058 posts
Posted 02 February 2020 - 09:47 PM
The slots should be horizontal as per just about every manual out there.
and use something to lock the flywheel.
Edited by nicklouse, 02 February 2020 - 09:48 PM.
#4 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 02 February 2020 - 10:33 PM
As Nick says,but regarding the other part of your question, you can remove the bolt with the flywheel anywhere it happens to be as long as you turn it to slot  horizontal before you start pulling
#5 cristiano1968
cristiano1968
  • 444 posts
Posted 02 February 2020 - 11:02 PM
Cheers?
#6 cristiano1968
cristiano1968
  • 444 posts
Posted 02 February 2020 - 11:11 PM
Cheers?
#7 AP2020
AP2020
  • 89 posts
Posted 05 February 2020 - 07:09 PM
Or in other words... with all 4 piston level with each other, ie 1/2 way down/up the bore
And when you reinstall it make sure you have piston number 1 at TDC
Edited by AP2020, 05 February 2020 - 07:43 PM.
#8 cristiano1968
cristiano1968
  • 444 posts
Posted 05 February 2020 - 11:13 PM
Ok ?
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,563 posts
  • Local Club: Amoc
Posted 08 February 2020 - 06:00 PM
Remember to take the washer out.. seen so many cranks ruined by this....
#10 cristiano1968
cristiano1968
  • 444 posts
Posted 13 February 2020 - 01:57 PM
Yes I will.
I will also grease the bolts on the flywheel puller,
I heard it helps
#11 bpirie1000
bpirie1000
  • Area Managers
  • 2,563 posts
  • Local Club: Amoc
Posted 19 February 2020 - 07:53 PM
Old used shell bearings are great to lock the flywheel...
#12 AP2020
AP2020
  • 89 posts
Posted 20 February 2020 - 09:47 AM
Yes I will.
I heard it helps
Greasing the bolts will only help if the bolts will hold the tension, have you looked at Guessworks gearboxes puller ? the 3 main criteria with the Guessworks puller are:-
1) large diameter thread with a very fine pitch spreads the load and makes it easier to turn
2) High tensile bolts, these will allow for higher loads to be applied.
3) Ball bearing centre pin reduces the loads that need to be applied to rotate the centre bolt.
These are what makes it a great puller, the normal aftermarket items have none of the above.
#13 cristiano1968
cristiano1968
  • 444 posts
Posted 20 February 2020 - 02:20 PM
Got it of
Used a draper flywheel puller
Thanks for all the advice
