Chrome Trim On Opening Rear Windows
7 replies to this topic
#1 Methaneman
Methaneman
  • 18 posts
Posted 03 February 2020 - 08:18 PM
Can the trim be taken off the glass and refitted.or does anybody know if its bonded on....
#2 absx2
absx2
  • 960 posts
Posted 03 February 2020 - 08:22 PM
It`s stainless steel and the glass is held by a rubber strip. Personally I refit the glass with black Sikaflex and trim off the excess when dry.
#3 Methaneman
Methaneman
  • 18 posts
Posted 03 February 2020 - 08:24 PM
Can you buy new chrome trim...??
#4 Chris1275gt
Chris1275gt
  • 1,050 posts
Posted 03 February 2020 - 08:50 PM
New stainless steel frames are no longer available. You can get good s/hand off eBay. You can get this seal from Minispares. 47H9535M It's a bit of a challenge getting it all back together and make sure the small screw that locks it all together goes in straight.
#5 Itsaminithing
Itsaminithing
  • 856 posts
  • Local Club: Not One Worth Mentioning
Posted 03 February 2020 - 09:05 PM
A word of caution IF the SPI window is the same as the MPI window then DO NOT try replacing the glass seal, .... original seals are unavailable, every parts supplier will try & sell you 47H9535M & you will end up bending the frame trying to get it too fit as the MPI glass is fractionally thicker than the earlier windows.
If you need to remove the frame to fit a replacement hinge or catch then absx2 has given you the best advice....
#6 Carlos W
Carlos W
  • 10,115 posts
Posted 03 February 2020 - 09:18 PM
I certainly couldn't get the new seal to fit. It just seemed to grip
#7 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 03 February 2020 - 11:49 PM
just about to do mine with Sikaflex
#8 Itsaminithing
Itsaminithing
  • 856 posts
Posted 04 February 2020 - 07:55 PM
The original Quarter Light Glass Seal was ALA5581, I'm fairly sure 47H9535M is thicker.
Some people have been lucky & got away with fitting 47H9535M with the earlier glass but it's definitely a no-go on MPI windows (& poss SPI -IF they are the same as the MPI).
I did find a source for a square profile EPD seal which should fit the MPI windows but that part of the project got shelved untill the shell is rust free (we can all dream).
