Oil Pump Question
7 replies to this topic
#1 1314cc
1314cc
  • 311 posts
  • Local Club: tumbleweedminisbristol
Posted 03 February 2020 - 09:50 PM
I've a 1275cc A+ engine. The oil pump is a 4 bolt fixing type but all the pumps online are 2 bolt. I haven't removed it yet but presume it's a slot drive?
Fitting a new 2 bolt will be ok??
I guess it's good pratice to replace oil pump whilst engine is apart.
#2 imack
imack
  • 2,382 posts
Posted 03 February 2020 - 09:55 PM
Are you sure it's four bolt? Usually two bolts mount the pump to the block and the other two bolts hold the top plate to the pump body.
#3 1314cc
1314cc
  • 311 posts
Posted 03 February 2020 - 10:04 PM
it has 4 bolts and 2 screws
I'll get a picture up tomorrow
Edited by 1314cc, 03 February 2020 - 10:11 PM.
#4 1314cc
1314cc
  • 311 posts
Posted 03 February 2020 - 10:41 PM
BLR-14 ?
#5 Spider
  • 15,873 posts
Posted 04 February 2020 - 04:02 AM
The earlier engines did have a 4 bolt pump fitted, when Slot or Spider Drive Pumps were used, though that one appears after market.
The Steel Backed 2 Bolt types Pumps are OK and are a direct replacement.
Yours is likely a Spider Drive, but I'd suggest removing it to see what it is for sure.
#6 1314cc
1314cc
  • 311 posts
Posted 04 February 2020 - 07:26 AM
a Kent cam 276 was fitted about 20 years ago . So would that tell me anything without looking? The pump is about 20 years old but the engine has only covered around 20,000 miles so could I possibly leave it? Guess it seems daft to
#7 nicklouse
  • 19,066 posts
Posted 04 February 2020 - 11:04 AM
nope it tells you nothing.
check its condition but most would say change it.
#8 1314cc
1314cc
  • 311 posts
Posted 04 February 2020 - 02:14 PM
I'll take a look soon then get back
cheers all
