Different Gearboxes
4 replies to this topic
#1 RallyRuss
RallyRuss
    Starting My Mini Up
  • Validating
  • 2 posts
Posted 04 February 2020 - 11:46 AM
I've got two mini engines with two different gearboxes and want to know if there is any real difference between them, can anyone tell me?? The numbers are A/BZ3 BC DAM5626 andA/BZ4 BC&M DAM 5626. Thankd
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 04 February 2020 - 12:57 PM
Are you wanting to know if you can swap an engine to another gearbox ?
#3 RallyRuss
RallyRuss
    Starting My Mini Up
  • Validating
  • 2 posts
Posted 04 February 2020 - 01:11 PM
I'm planning on putting straight cut gears in one of the boxes and using it on a 1275. Just wasn't sure if one would be better to use than the other. Thanks
#4 nicklouse
  • 19,057 posts
Posted 04 February 2020 - 01:21 PM
Both the same casting.
#5 Ethel
  • 26,789 posts
Posted 04 February 2020 - 02:06 PM
You'd be best off stripping both. There are plenty of bits that don't come in a straight cut set that you'll need to reuse or replace.
