New Dizzy
4 replies to this topic
#1 maystro
maystro
  • 42 posts
Posted 09 February 2020 - 11:08 AM
Hey Guy's,
I have a 1981 Australian Leyland Moke, A+ I guess is what some may call the engine.
I want to up grade the ignition so thinking about putting a electronic dizzy in.  I found this unit close to home on ebay.
https://www.ebay.com...IkAAOSwzL9dkxcu
Will this fit my motor?  Also when they say electronic are they talking about a pointless system?
Also the one I have at the moment has a vacuum advance but there is no hose going to it.  I think a mechanic disconnected it at some point in time.
Should I get a hose and reconnect if I get this new or try and get a mechanical advance dizzy?
Brad
#2 Moke Spider
Moke Spider
  • 9,647 posts
Posted 09 February 2020 - 11:32 AM
Have a read here first
http://www.theminifo...d-distributors/
#3 Moke Spider
Moke Spider
  • 9,647 posts
Posted 09 February 2020 - 05:27 PM
If you are going to replace your distributor, I would suggest one of these;-
https://www.minispar...|Back to search
They are not only good value for money, but actually have the correct advance curves. I've tested a lot of after market distributors from all over the world and these are the only off the shelf ones I've found that are actually correct.
#4 maystro
maystro
  • 42 posts
Posted 10 February 2020 - 11:06 AM
I think your an Aussie guy too.  How is the postage from the UK to Australia?
#5 Moke Spider
Moke Spider
  • 9,647 posts
Posted 10 February 2020 - 04:42 PM
I did notice in Tony's ebay advert, his distributors are 'fits all engines', which is enough to make me run away.
Bhahaha,,,,, I was last time I looked (about 3 days South of you).
By default, Mini Spares send parcels by DHL and usually around a week to receive them, but for 1 or 2 items, it can be a little expensive.
If you ask (or there's an option) for post, it would be cheaper and isn't too bad at all, but take a little longer.
Mini Spares
