Can Someone Measure Rear Window Opening
No replies to this topic
#1 Verderad
Verderad
  • 413 posts
Posted 09 February 2020 - 08:22 PM
I’m about to tack replacement rear panel into place
Before I pull the trigger I want to check what the opening should be
The measurements I took before removing the lower part of the rear panel.
Measurements looking at rear of car left to right
Approx 150mm from C Post 360mm
Approx 350mm from C Post 366mm
Centre 367mm
From right C Post
Approx 150mm from C Post 363mm
Approx 350mm from C Post 367mm
To get the profile around the window to align between existing and new panel I need to adjust this by a few mm
Wanted to check the tolerance on window opening so I can still get the glass in.
Edited by Verderad, 10 February 2020 - 08:47 PM.
