Dismantling A Drive Shaft
Best Answer luismx123 , 10 February 2020 - 01:25 PM
check the video from Stevestons motor company on axle rebuilding. I just did this this weekend as my pot joint gaiter was ripped. A reason for it not coming off could be: you are not hitting it hard enough/correctly, or - like in my case - the joint is siezed on the axle. I had to remove the CV joint to change the gaiter for the pot joint as my pot joint end is completely stuck on.
Go to the full post
4 replies to this topic
#1 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 10 February 2020 - 12:24 AM
I'm not having success following my service manual instructions. Any suggestions?
Thanks in advance.
Brian
Attached File  20200209_190748.jpg   22.24K   5 downloads
Attached File  20200209_190432.jpg   22.62K   6 downloads
#2 nicklouse
  • 19,067 posts
Posted 10 February 2020 - 12:25 AM
Bigger hammer.
or buy a CV puller.
#3 Tupers
Tupers
  • 4,176 posts
Posted 10 February 2020 - 01:07 AM
Normally they’ll pop off with a good blow from my Thor copper hammer but if not try holding the drive shaft in the bench vice with the CV pointing down and place a blunt chisel on the inner race of the joint and strike that.
A more direct blow to the part that’s actually holding it on can help.
#4 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 10 February 2020 - 12:31 PM
Having just done this with an old set of shafts and outer CVs they do come off :-)
I put the drive shaft in the vice and tapped the outer ring of the CV housing with a lump hammer. Be careful to hit it square on and you may need to rotate the shaft in the vice.
#5 luismx123
luismx123
  • 525 posts
Posted 10 February 2020 - 01:25 PM   Best Answer
