Engine Number Checker
27 replies to this topic
#1 nollyd
nollyd
  • 663 posts
Posted 12 February 2020 - 08:17 PM
Hi all,just need a little help,thinking of buying this engine,need info about it though,please help.
10H 791AA2
There are more numbers tho not sure if they are needed.cheers guys.
#2 nollyd
nollyd
  • 663 posts
Is it a or a+ also.
#3 nicklouse
  • 19,064 posts
Posted 12 February 2020 - 08:24 PM
http://www.guess-wor...Tech/engine.htm
#4 nollyd
nollyd
  • 663 posts
Posted 12 February 2020 - 08:25 PM
Been on that but goes to some site selling handbags n stuff
#5 nicklouse
  • 19,064 posts
Posted 12 February 2020 - 08:29 PM
There were no 1100 A+ engines.
it is out of a Clubman Saloon.
#6 nollyd
nollyd
  • 663 posts
Posted 12 February 2020 - 08:35 PM
It shows signs of a+,
Webbing by where oil filter bolts on,what else can i check from a photo.
#7 nollyd
nollyd
  • 663 posts
Posted 12 February 2020 - 08:38 PM
Timing chain cover is not just egg shaped,it has the kink for tensioner.
#8 nicklouse
  • 19,064 posts
Posted 12 February 2020 - 10:14 PM
no it shows signs of not being original.
or that it was build at the end of 1980 when the A plus was coming in.
there were no A+ 1098 listed.
Edited by nicklouse, 12 February 2020 - 10:21 PM.
#9 beardylondon
beardylondon
  • 1,802 posts
Posted 12 February 2020 - 10:37 PM
you are clearly using the wrong website this works fine, it does get shortened for some reason
guess-works.com
just click this link:
Edited by beardylondon, 12 February 2020 - 10:38 PM.
#10 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 12 February 2020 - 10:41 PM
you are clearly using the wrong website this works fine, it does get shortened for some reason, just click this link
its is guess-works.com
For some reason the link goes to ".com" rather than ".co.uk". if my link below doesn't work just change the ".com" bit to ".co.uk" and it will work.
#11 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 12 February 2020 - 11:05 PM
A 791 coded engine isn't available on the Guessworks site....
#12 nicklouse
  • 19,064 posts
Posted 12 February 2020 - 11:07 PM
which is why I updated my answer with the correct info.
#13 beardylondon
beardylondon
  • 1,802 posts
they own both domains, forwards to the same thing
guess-works.co.uk
and
guess-works.com
notice the hyphen.
however they also appear to own the below without the hyphen.
guessworks.co.uk
#14 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 12 February 2020 - 11:12 PM
You certainly know more than me, every day is a school day ?
#15 Itsaminithing
Itsaminithing
  • 856 posts
  • Local Club: Not One Worth Mentioning
Posted 13 February 2020 - 12:00 AM
10H791AA   =  1100 Mini Clubman saloon.
On 1100 engines If it's got a dipstick tube then it's A series, if the dipstick goes directly into the block then it's an early A+ (rare but it seems they did exist).
Edited by Itsaminithing, 13 February 2020 - 12:03 AM.
