Subframes?
8 replies to this topic
#1 781275
781275
  • Just Joined
  • 11 posts
Posted 14 February 2020 - 11:28 PM
So I'm going to be rebuilding both subframes.
Front will be media blasted and powder coated.
I will be buying a new genuine rear one but the question is do these require any extra painting?
You can only buy a non genuine rear subframe powdercoated.
What has everyone else done?
Your thought would be much appreciated, thanks.
#2 nicklouse
  • 19,067 posts
Posted 14 February 2020 - 11:33 PM
Don’t powered coat. 2k epoxy it.
powder coat chips then let’s water in and you can’t touch it up.
#3 781275
781275
  • Just Joined
  • 11 posts
Posted 14 February 2020 - 11:37 PM
To both subframes, even the new rear?
#4 Tupers
Tupers
  • 4,176 posts
Posted 15 February 2020 - 01:22 AM
The Heritage rear subframe will come in E-coat which will not survive on its own.
As Nick has said I paint my subframes in 2K black. It’s hard wearing and unlike powder coating it can be touched up. Once you have a chip or crack in powder coat water can get trapped underneath it and cause rust.
#5 mab01uk
mab01uk
  • 13,092 posts
Posted 15 February 2020 - 11:51 AM
Never understood why some like powder coating everything, sounds good and looks good for a while.....but as said once it chips it makes rust & corrosion worse.
Edited by mab01uk, 15 February 2020 - 11:52 AM.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 15 February 2020 - 12:11 PM
Powdercoat properly applied will last, you can get the subframe galvanised first then powder coated.  Paint chips as well so unless you are under your car every time you take it out to check for any stone chip damage then things will happen.
Your choice, your car. Go with what YOU want to do.
#7 781275
781275
  • Just Joined
  • 11 posts
Posted 18 February 2020 - 10:31 AM
Thank for the advise, good to know the rear will need painted and doesn't come ready to go on, have beed looking into 2k paint,
#8 humph
humph
    How bad can it Be?
  • 1,125 posts
Posted 18 February 2020 - 02:59 PM
Anyone used this stuff?
https://www.rust.co....poxy-mastic-326
#9 sonscar
sonscar
  • 3,258 posts
Posted 19 February 2020 - 09:28 AM
Yes.Left a shell outdoors in a tent for 3 years after acid dipping and painting with this and no rust formed.Needs the correct thickness coats.Steve..
