Outer Sill
6 replies to this topic
#1 Benito_S6
Benito_S6
  • 89 posts
Posted 15 February 2020 - 12:19 AM
Hi again, has anyone seen this type of outer sill before? Surely not oversills but they look different to other genuine outer sills to me. Could you let me know whether they are ok as I think and if there are correct?
Edited by Benito_S6, 15 February 2020 - 07:32 AM.
#2 Tupers
Tupers
  • 4,176 posts
Posted 15 February 2020 - 02:06 AM
That looks like a 6” MK1/2/3 cover sill.
They also came in 8” that had closed vents and went right down to the horizontal section of the floor.
#3 Benito_S6
Benito_S6
  • 89 posts
Posted 15 February 2020 - 07:10 AM
Ah reyt thanks so they are a type of cover sill. I’d never heard of a open type of cover sill but obviously know all about how bad the closed vents ones are. Are they as bad as them and should I totally avoid or are they ok as they are still vented? I can see how it comes lower down than a standard sill now you’ve said. Looks like it could just be a non genuine sill fitted rather than a sill over the top of the original ones IMO, what do you reckon?
Edited by Benito_S6, 15 February 2020 - 07:16 AM.
#4 Benito_S6
Benito_S6
  • 89 posts
Posted 15 February 2020 - 07:38 AM
by the way spot on tuppers definitely these ones. The minis been off the road for 9 years so could just be the case that the old ones were cut off and these were fitted rather than a genuine one. If rover supplied them and they are vented they surely they can’t be that bad?
#5 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 15 February 2020 - 08:00 AM
Aslong as the old one was removed they will be fine
#6 Benito_S6
Benito_S6
  • 89 posts
Posted 15 February 2020 - 08:19 AM
Sound mate just as I thought. Thanks a lot
#7 mab01uk
mab01uk
  • 13,084 posts
Posted 15 February 2020 - 11:48 AM
Also worth pumping some Waxoyl up into the sills via the vents, also via seat belt bolt holes and from inside the rear side pockets via any convenient holes.
https://www.hammerit...product/waxoyl/
Edited by mab01uk, 15 February 2020 - 11:49 AM.
