1275Gt New Brakes Problem
2 replies to this topic
#1 RRM
RRM
    Starting My Mini Up
  • 3 posts
  • Local Club: Barkham . District CCC
Posted 15 February 2020 - 09:35 AM
Hello,
I've been a long term Mini enthusiast and have an Elf and a 1977 1275GT which I'm restoring from scratch. I am having an unexpected problem with the brakes and seek advice: It has an early, simple diagonal split system and I've replaced everything with completely new parts: New GMC167 tandem master cylinder. Silicone brake fluid. When I try to bleed the system, the N/S front to O/S rear circuit bleeds normally but the o/s front to N/s rear gets no pressure at either nipple, just gravity fed odd drip. This happens no matter how much I repeatedly or rapidly pump the brake pedal and I get no pressure from the pedal either. The totally new parts are fitted exactly as per the old circuitry. (The only thing I reused is the failure switch screwed into the master cylinder body to replace the blanking bolt it came with because of apparent non-availability of this part now). There are no leaks along the pipes or from the new cylinders or calipers. Any thoughts or ideas please??
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 15 February 2020 - 10:02 AM
Hi and welcome toTMF.
You say you have replaced / overhauled all of the parts but have you checked the orientation of the front callipers to ensure they are fitted to the correct side ie bleed nipple upper most???
#3 Ronski
Ronski
  • 13 posts
Posted 15 February 2020 - 03:12 PM
If your using a pressure bleeder you could take the pipe out the master cylinder for the offending curcuit, connect a suitable pipe from the pressure bleeder to the pipe and then see if fluid flows properly from the bleed nipples, if it does then the faults in the master cylinder.
