Hello
I Got Just one little question ..
Can i put the Sportpack arches with 12" Wheels and avoid cutting the body ?
Thank you
Posted 20 February 2020 - 10:01 AM
Hello
Thank you
Posted 20 February 2020 - 01:09 PM
You'll have to drill new holes for the sportspack arches, but depending on what 12" wheels you had, you may have to do some minor trimming.
Posted 20 February 2020 - 01:52 PM
the wheels i got are not deep...
but i'm planning to put in the future the Dunlop 10"
i just want to avoid to cut the body of the mini ... just put the arches, if it's just a matter of drilling new holes that's Okay !!!
Posted 20 February 2020 - 02:20 PM
The thing is, if the wheels don't stick out far enough, then the sportspack arches just don't look right, and to get them to look right, your wheels will hit the front wings / front panel when you turn the wheels.
Edited by pete l, 20 February 2020 - 02:21 PM.
Posted 08 March 2020 - 08:35 AM
Posted 09 March 2020 - 05:06 PM
The Sportspack arches are quite bulky and work really well aesthetically with 13" wheels, both standard Sportspack and aftermarket wheels, IMHO if you're fitting 10" wheels the scale of the arches will be completely wrong and something more delicate in appearance works better.
Agreed that 90% of the time, sportpack arches are fitted together with 13'' wheels, but they can definitely work with 10'' wheels.
Case in point (not mine)
Posted 09 March 2020 - 05:27 PM
Posted 04 April 2020 - 06:39 PM
Edited by malynch27, 04 April 2020 - 07:09 PM.
Posted 07 April 2020 - 10:53 AM
To be blunt, 10" or 12" wheels do not match with the wide Sportpack arch exensions.
The widest tyre you can get in 10" or 12" is a 165 section width and they should not be fitted onto wheels wider than 6". Putting spacers on is always a bad idea as they spoil the road-holding by altering the ideal steering geometry.
If you like very wide arch extensions you will really have to fit 13" wheels so that the wider low-profile tyres can be fitted in order to meet the tyre regulations.
With a 10" wheel there are two choices really. To run a 4.5" wheel with 165/70 x 10 tyres and not have any arch extensions, just carry the chrome trim the arches, or to run a 5" or 6" with the old so-called 'Group 2' arches. The same really applies to 12" wheels.
The big advantages with no arch extensions are there are no holes drilled into the body, so less rust, and not fitting extensions does, to many, look much better. There is also less aerodynamic drag, so it'll go a bit quicker .
