Personally I always use hex. head 5/16" UNF bolts 1.25" long. You do need the big washers for 4 of the bolt/stud positions and normal flat washers at each end bolt/stud.
The big advantage of bolts is the ability to remove the head without disturbing any of the engine steadies.
Sounds like a clever idea. On my A35 the engine is low down in the bay so making it easier to remove the manifolds is a good move. Anything else special about them? Grade, etc?
