Hi fellow mini friends.. I've got an MPI mini with the usual cold idle issue, which is probably iacv which is on order but am unsure if the map sensor or something else electronic is causing me any issues with stuttering within the 2000-2500 rev range... Is there anyone in Kent with a diagnostic tool that I can use to give it a full check over?
Any help.is much appreciated! Thanks
Rover Mini 2000 In Need Of Diagnostic Tool (Kent)
SenoritaSwag
, Feb 22 2020 09:12 PM
No replies to this topic
