Fitting A 5.5 Gallon Rh Tank
6 replies to this topic
#1 croc7
croc7
  • 752 posts
Posted 23 February 2020 - 01:05 AM
Has anyone else had trouble installing a new RH tank from Mini Spares?  My old one, an original, fit fine but had developed a slight leak so out it went.  The new one appears to be a fine replica but I can't get it past the bracket that holds the boot cable.  I think that the tank seam might be a little 'taller' than the original tank.  Right now, it looks like I have two options;  trim the bracket or trim the seam on the tank but I don't know how 'deep' to trim the tank seam without causing a leak.  About .3" is all the room I need.  Any input would be appreciated.
Edited by croc7, 23 February 2020 - 01:05 AM.
#2 JVA10L
JVA10L
  • 181 posts
Posted 24 February 2020 - 01:47 PM
Same problem here. I trimmed the bracket off as I only ever use one boot cable anyway.
#3 croc7
croc7
  • 752 posts
Posted 24 February 2020 - 08:33 PM
I'm in the process of trimming the tank seam to within about an 1/8" of the crimp on the perimeter of the tank.  Shouldn't leak.  If it does, I'll have lost a good bit of money, reinstall the old one, plug the interconnecting fuel line between the two and run a single 7.5 gallon tank.  I had a feeling this would turn into a science project.......
#4 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 24 February 2020 - 09:05 PM
Can you not just bend it slightly to get the clearance you need?
#5 Quinlan minor
Quinlan minor
  • 992 posts
  • Local Club: LSMOC
Posted 24 February 2020 - 09:09 PM
The OEM left tank in mine has a significant bend in the seam, presumably to get past that, so bending seems to be the way to go.
#6 croc7
croc7
  • 752 posts
Posted 25 February 2020 - 02:23 AM
No, the tank seam, as fitted, overlaps the cable bracket by about .3".  Going primitive with a belt sander tonight. :gimme:
#7 croc7
croc7
  • 752 posts
Posted 25 February 2020 - 07:50 PM
Trimmed the seam all around to within 1/8" of crimp, close,but still couldn't get past the cable bracket.  ZIP, now it fits!
