Huh? White Gunk Inside Rocker Cover
Best Answer Mini Manannán , 26 February 2020 - 01:38 PM
What was different about the swiftune one?
The Swiftune cap is made of ally, the Metro is plastic.
Go to the full post#1
Posted 23 February 2020 - 12:18 PM
Posted 23 February 2020 - 12:24 PM
Not using it enough. The water that condenses in the engine voids is not been removed by getting the engine up to temp for long enough.
As Nicklouse says use it more or run it to temperature and keep it running for a while
Edited by cal844, 23 February 2020 - 12:25 PM.
Posted 23 February 2020 - 12:25 PM
So if no loss of coolant at all then i would say its down to short journeys not allowing the engine to warm up.
So what have you done from a work point of view???
Posted 23 February 2020 - 12:32 PM
I wouldn`t panic just yet, as above it`s 2 degrees C and 70% humidity where you are so it probably needs a good run to cook off the moisture.
Obviously wipe that gunk off before putting it back on and check your fluids, hopefully not a head gasket issue.
Posted 23 February 2020 - 12:49 PM
Thx guys and has been sitting for a bit and just noticed the thermostat is not working, bought a new 88 degree and putting in now, taking for a run and will advise shortly.
To answer question above about what I have done, just booting back in a stage 3 head and torqued it down is all
Posted 23 February 2020 - 08:51 PM
Posted 23 February 2020 - 09:06 PM
Have you just fitted the head without any other changes? ?
Hey Blacktulip, a few things
BP255 CAM
CST2001 head
1.4.1 rockers
Sport coil
Aldon dizzy
Iridium plugs 0.40 gap
70 amp alternator
Etc etc
Edited by postve, 23 February 2020 - 09:08 PM.
Posted 23 February 2020 - 09:14 PM
Should be nice on the road ?
Hey Blacktulip, a few thingsHave you just fitted the head without any other changes? ?
BP255 CAM
CST2001 head
1.4.1 rockers
Sport coil
Aldon dizzy
70 amp alternator
Etc etc
Posted 23 February 2020 - 10:42 PM
Poor Crankcase ventilation will also do that. There's not only needs to be a 'draw out' point but flow through ventilation. Usually, Air is admitted in to the Rocker Cover via the cap.
Posted 23 February 2020 - 11:46 PM
Edited by postve, 24 February 2020 - 12:15 AM.
Posted 26 February 2020 - 08:51 AM
What rocker cover cap are you using? I had your problem all the time I was using a Swiftune cap, changed to a red Metro cap and the mushroom soup completely disappeared.
Posted 26 February 2020 - 10:27 AM
Let me give that a try as I have the original cap still hanging around - thx
Posted 26 February 2020 - 10:45 AM
Posted 26 February 2020 - 01:17 PM
also some oils are more prone to this,
