Spot Weld Drill
Posted 24 February 2020 - 07:22 AM
Cheers ?
Posted 24 February 2020 - 07:27 AM
Ive used the second type - mini hole saw with a spring loaded point. Worked really well to be fair, pretty straight forward, but I think its better suited for metal work that wont get re-welded/repaired. I used it to remove the lip on my bonnet to convert to a mk1 grille from the mk3/later types. They dont last extremely long and after drilling out all the spots on the bonnet I had to flip the cutter one time as it was getting dull.
Posted 24 February 2020 - 10:46 AM
I am using the first type. Flat head with a centering pin.
Works very well and does drill nice round holes with very minimal burrs.
I have two of them, one quite cheap (less than 10€), the other one from Würth, for a little more, which seems to work better.
Then there are some for 30+€ available, but I can't say anything on them.
The first one is curently reshaped as it wore out quite quickly (made a lot of holes too...) and it's about 5 quids too recut it.
I don't know about the second type, they seem qualitatilely better,
Hope this helps.
Gilles
Posted 24 February 2020 - 11:33 AM
They’re pricey but very effective and can be sharpened on a good square bench grinder stone. Always centre punch weld and then go in with the Dormer bit with a little cutting oil on it and keep the bit square to the panel.
Posted 24 February 2020 - 01:56 PM
its worth gettiing the cobalt one like linked above by tuppers,
Ive found they last well if you use them in a cordless on low speed so they dont get hot.
Posted 24 February 2020 - 04:40 PM
thanks all much apricate the input il go for the normal drill bit type
Posted 24 February 2020 - 09:35 PM
Another vote for the cobalt ones, the hole saw ones tend to be quite fragile if the spot weld is on an edge (like a mini wing for example). I used to find they broke reguarly whereas the cobalt ones are really tough and last for ages.
