Next steps, considering a modified ram air set up as follows and looking for those who have experienced the same and if value is there?
Similar to the following.
Best Answer postve , 11 March 2020 - 07:42 PM
Don't think that you can go wrong with the filter/velocity stack assembly from MED. Induction noise is a bit loud but I like it.
I just ordered the stub stack from MED today - first step into the void..
Go to the full postPosted 01 March 2020 - 12:37 AM
Posted 01 March 2020 - 12:53 AM
Pointless. Ducting air to the carb in general is good but the filter ain’t going to help.
Posted 01 March 2020 - 01:56 AM
Edited by postve, 01 March 2020 - 01:57 AM.
Posted 01 March 2020 - 02:33 AM
That type of filter is fine for a turbo but for an NA car using the words ram air is totally incorrect. It is just a colder air inlet. Which you have an your standard air filter any way.
second time I have posted this this week. (Maybe not on here though)
have a read https://www.calverst...air-filtration/
Posted 01 March 2020 - 02:49 AM
Posted 01 March 2020 - 07:37 AM
If you choose to go your own path, then may i suggest a trusty wide band AFR gauge. - something like an innovate item ( but any using a good quality bosch sensor)
Posted 01 March 2020 - 11:07 AM
Posted 01 March 2020 - 12:13 PM
I simply have no choice earwax as a rolling road is not an option or even available over here and yes I picked up an AFR last monthIf you choose to go your own path, then may i suggest a trusty wide band AFR gauge. - something like an innovate item ( but any using a good quality bosch sensor)
Edited by postve, 01 March 2020 - 12:16 PM.
Posted 01 March 2020 - 12:15 PM
I have an MGB with injection and data logging.It has a filter behind the grill leading directly to the inlet plenum.I removed the filter and logged the MAP.Up to 70mph there was no increase in MAP value.With lots of development and higher speeds(think older F1cars) it might work.Just my experience,yours may differ.Steve..
Posted 01 March 2020 - 05:17 PM
Posted 02 March 2020 - 12:39 AM
Posted 11 March 2020 - 07:42 PM Best Answer
