1098 Thrusts
Best Answer ACDodd , 14 March 2020 - 02:20 PM
Stock ones are 0.092" nominal +/- 0.001"
Typically.
Ac Go to the full post
17 replies to this topic
#1 whistler
whistler
  • 1,706 posts
Posted 13 March 2020 - 04:39 PM
Does anyone know what the standard crankshaft thrust thickness is please for a 1098/998?
My current worn ones are 0.0890/895". I have 12 thou endfloat. Oversize thrust are very rare now; only Thorntons seem to have them but I need to know if +0.003 size will reduce my float to the correct size or if I have to go on the hunt for 0.030" ones and have them skimmed.
Thanks.
#2 whistler
whistler
  • 1,706 posts
Posted 13 March 2020 - 04:44 PM
Just found +0.005 and +0.030" on Somerfords site.
BHM1292.
Can order the correct ones now when I find ot what my STD ones should be.
#3 unburntfuelinthemorning
  • 1,915 posts
Posted 13 March 2020 - 04:51 PM
From my terribly badly written notes I do believe that my new standard sized thrust washers for my 998 were 0.093".
#4 DeadSquare
DeadSquare
  • 2,766 posts
Posted 13 March 2020 - 07:03 PM
BHM1292.
Somerfords will tell you, if you say "Please".
#5 whistler
whistler
  • 1,706 posts
Posted 13 March 2020 - 08:07 PM
BHM1292.
I'll give them a ring, they've been helpful in the past when I've spoken to them. Thanks.
#6 1314cc
1314cc
  • 301 posts
  • Local Club: tumbleweedminisbristol
Posted 13 March 2020 - 09:03 PM
i just done mine on my 1275cc so not sure if they're the same thickness. I bought mine on eBay and standard new thrusts are around 92thou and my +3 We're 95thou. Fitting new standard thrusts brought my float down to 6 thou. So I got the +3 to get it down some more
#7 1314cc
1314cc
  • 301 posts
Posted 13 March 2020 - 09:10 PM
when I measured up my old thrusts I'd lost around 10 thou . I'd try new standard then see where you are first
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 13 March 2020 - 11:55 PM
I have STD, +0.004", 0.005" and +0.015" in stock.
Ac
#9 whistler
whistler
  • 1,706 posts
Posted 14 March 2020 - 09:56 AM
Ac
Thanks. Are you able to tell me what the STD thickness is? My current ones are 0.089/0.0895"
#10 Cooperman
  • 23,039 posts
Posted 14 March 2020 - 11:23 AM
At 'trial build' stage I always fit a pair of standard thickness thrusts. Then I measure the end float and any required additional thickness can be established.
If you need more than the available oversizes, you can get a pair of +0.030" ad have them surface ground to the correct thickness to give the recommended end-float. Remember to grind the steel backing side!
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 14 March 2020 - 02:20 PM   Best Answer
Typically.
Ac
#12 Spider
  • 13,927 posts
Posted 14 March 2020 - 05:37 PM
According to ACL, who were an OEM Manufacturer, they are 0.093" Thick
#13 DeadSquare
DeadSquare
  • 2,766 posts
Posted 14 March 2020 - 05:48 PM
I always thought that SDT thrust washers were 3/32". or .9375"
#14 ACDodd
ACDodd
  • Mini Docs
  • 2,657 posts
Posted 14 March 2020 - 07:04 PM
Hehehe I love this, yeah maybe they were, they ain't now! I just measured a set of glaciers. Stop looking in books and actually measure what turns up in packets.
Ac
Edited by ACDodd, 14 March 2020 - 07:08 PM.
#15 unburntfuelinthemorning
  • 1,915 posts
Posted 14 March 2020 - 11:13 PM
Ac
Mine are ACL and measured 0.093" which is nice as it appears that's what they're meant to be.
