Looking for a set of coilover brackets. Thanks
Edited by simonaoz, 15 March 2020 - 10:26 AM.
Posted 15 March 2020 - 10:21 AM
Posted 15 March 2020 - 11:15 AM
Upper or lower?
ps they are not very good as the positions are totally wrong. When compressed the coilover and top pivot points should make a 90 degree angle.
so unless you are cutting away your inner wing to correctly mount them I would not bother buying any unless it is the lower ones you want.
Posted 15 March 2020 - 12:35 PM
It's both brackets that I'm after. Yes the inner wings are coming out. I'm doing a VTEC B16 swap.
Posted 15 March 2020 - 12:53 PM
then make your own up. it aint hard and you can get it right. rather than getting the incorrect ones supplied.
