Electrical Or Mechanical Water Temp Gauge
12 replies to this topic
#1 minicooperr
minicooperr
  • 277 posts
Posted 15 March 2020 - 04:54 PM
As above, looking to fit a stack water temp gauge but they come in two variants electrical or mechanical, which is best/ easiest to fit?
thanks
#2 tmsmini
tmsmini
  • 760 posts
  • Local Club: MOASF
Posted 15 March 2020 - 05:10 PM
Caerbont has been having issues with the mechanical versions of the temp gauges. I returned a few and am still waiting on replacements.
Although this was before Christmas and the problem could have been resolved by now.
#3 minicooperr
minicooperr
  • 277 posts
Posted 15 March 2020 - 05:19 PM
I’m looking at stack gauges but is it a mechanical gauge that fits to the a series? I know you can buy a sensor so I assume that’s for the electrical but can you do the same with the mechanical?
#4 Spider
  • 15,850 posts
Posted 15 March 2020 - 05:46 PM
Mechanical gauges usually have a capillary tube and a (sensor) bulb that's directly attached to the back of the gauge and not removable. This is because they are filled with a gas or fluid.
It does also make them a bit harder to fit and potentially have a messy appearance particularly if the Capillary is too long or too short - you simply can't sinp some off or add some more on.
They are generally regarded as more accurate and more reliable though.
I did run with them for many years, but I'm over their short comings - just my personal choice on that. I've been exclusively running electric gauges (Smiths) for over 10 years now and while I have found issues with senders not being matched to the gauges, I have found them highly reliable and I don't see myself ever going back to mechanical gauges.
The issues with the senders I've found is that they haven't been matched to the gauges. For a short while, I just put up with it and leaned to read the gauge and I could see what was normal and what wasn't. I've since obtained the correct senders from Smiths, however, these need and adaptor to fit in Mini Cylinder Heads.
#5 Zami
Zami
  • 185 posts
Posted 16 March 2020 - 02:48 AM
I did run with them for many years, but I'm over their short comings - just my personal choice on that. I've been exclusively running electric gauges (Smiths) for over 10 years now and while I have found issues with senders not bI eing matched to the gauges, I have found them highly reliable and I don't see myself ever going back to mechanical gauges
I seem to recall a list with the p/n of the senders with the corresponding P/n matched gauge. Does anyone have a copy they could share.
#6 minicooperr
minicooperr
  • 277 posts
Posted 19 March 2020 - 10:35 AM
I have bought a mechanical one and the probe on the end is about 4cm long, will this fit in the standard position?
#7 DeadSquare
DeadSquare
  • 3,382 posts
Posted 19 March 2020 - 11:15 AM
The simple answer is, see if there is 4cm of space for it, and carefully try it.
#8 minicooperr
minicooperr
  • 277 posts
Posted 19 March 2020 - 11:25 AM
Its not currently drilled so dont fancy drilling it if it wont work and have to put it somewhere else
#9 DeadSquare
DeadSquare
  • 3,382 posts
Posted 19 March 2020 - 12:22 PM
Has it come with an adapter, or does it screw into the head ?
If it has an adapter, it would be easier to solder the adapter into the radiator.
#10 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 19 March 2020 - 02:06 PM
That's not the best place to get a true temp reading though ... what about a thermostat housing with a sender hole?
#11 Spider
  • 15,850 posts
Posted 19 March 2020 - 06:28 PM
As far as I am aware, there has only be 3 for the Mini;-
     Very Early type matched to the early Gauges. These didn't use a Voltage Stabaliser.
     Those matched to 82 degree Thermostats, and
     Those matched to 88 degree Thermostats
These last 2 use the same Gauge or the same characteristics. The reason for the change with the Thermostat is so that when at normal operating Temp, the Gauge read ' N '
#12 timmy850
timmy850
  • 3,605 posts
  • Local Club: MITG
Posted 19 March 2020 - 07:49 PM
I like the mechanical gauge in mine. There’s guaranteed to be no electrical problems, it reads when the engine is off and it’s accurate and has a scale in deg C. Mines was a NOS Stewart Warner gauge when I bought it years ago and it just works!
#13 jt19
jt19
  • 745 posts
Posted 20 September 2020 - 10:49 AM
I use a mechanical gauge. Always have.
I've been wondering recently though, does the capilery tube suffer with heat soak?
