Really Difficult To Get Into Fourth Gear With Car Running Or Not
6 replies to this topic
#1 minicooperr
minicooperr
  • 277 posts
Posted 17 March 2020 - 03:38 PM
Cant seem to get into fourth without really slamming it in, have recently had the gear linkage off to fit a kad but not sure what I could have done here?
#2 Ethel
  • 26,826 posts
Posted 18 March 2020 - 02:26 AM
Catching the reverse gate do-dah on the selector cover plate?
What's a kad, summet made by KAD?
#3 Spider
  • 15,879 posts
Posted 18 March 2020 - 04:55 AM
If you have the rubber bellows fitted on the Shift Rod, in front of the Coupling, cut it off.
#4 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 18 March 2020 - 08:10 AM
Short shifts can cause issues with gear selections.
#5 MacGyver
MacGyver
  • 1,028 posts
Posted 18 March 2020 - 05:11 PM
Underplate back to front? Do you stil need to lift for reverse?
#6 MrE812
MrE812
  • 39 posts
  • Local Club: ELMOC
Posted 21 March 2020 - 08:20 PM
Hmm... if all you've changed is the gear stick (assuming you fitted a KAD quick shift stick?).
I've recently experienced the issue of refitting the rod change after years off the car and managed to get the yoke upside down.
The symptoms I had were gears 1 through 4 engaged but it felt sloppy - could not get reverse at all.
Not exactly what you've got but might be helpful.
Make sure the roll pins haven't drifted out and aren't fouling the diff casing.
it's a PIA but worth double checking the yoke under the gear shift isn't inverted.
This way up...
#7 minicooperr
minicooperr
  • 277 posts
Posted 27 March 2020 - 09:41 AM
I ended up taking it all back apart ensuring the yoke was the correct way up, cleaned and regreased and now seems to be right, not sure what I did wrong but working now
