Thanks in advance
Rear Opening Window Frame Screw
Best Answer Compdoc , 18 March 2020 - 08:20 PM
I believe these screws are countersunk 6-32 UNC x 1/4" long. These are used in some instances to hold the power supply into a standard PC case, so stealing one from there might do the trick.
Go to the full post
Posted 17 March 2020 - 07:02 PM
Thanks in advance
Posted 17 March 2020 - 08:06 PM
rivet wont work as theres no room mate il have a look at some old windows I have
Posted 18 March 2020 - 08:22 AM
http://www.somerford...page=page&id=40
not sure if this would help. my flash player is not working so i cant see the images for the screws in thier locations.
Edited by jaysmini1983, 18 March 2020 - 08:28 AM.
Posted 18 March 2020 - 09:46 AM
Cheers fella, much appreciated
Thanks fella, had a look on there already and unfortunately there is no seperate listing for the particular screw i need.
Sure it must be available somewhere just trying to work out what size and thread etc it was before it was mullered
Posted 18 March 2020 - 10:03 AM
might be worth calling somerford directly
Posted 18 March 2020 - 11:11 AM
Posted 18 March 2020 - 02:31 PM
Why don't you take the screw out of the other side measure it then look for a selt tapping screw of the same size shank and cut it down to fit.
Car is right up against the wall that side, but if nobody knows on here, i shall move some stuff and turn it around and do as you suggest.
Posted 18 March 2020 - 03:04 PM
ive got some screws out of an old window mate
Posted 18 March 2020 - 08:20 PM Best Answer
Posted 19 March 2020 - 11:01 AM
Can anyone help with the below?
Thanks in advance
I think this is what you're looking for.
https://www.ebay.co....UcAAOSw7I5TsBx4
Posted 19 March 2020 - 11:24 AM
You are a hero! Thanks for working out the specs, I had tried to raid some old PCs here already but no such luck. Many thanks for your help, ordered some :)
Thanks in advance
Great thanks buddy, have ordered these exact ones :)
Posted 19 March 2020 - 02:28 PM
http://www.somerford...roducts_id=2253
they are line 15. not sure they are correct as they say for the catch.
hopefully they work for you
