Starter Kill Switch?
Best Answer DeadSquare , 19 March 2020 - 02:34 PM
Pull the wire off the starter solenoid, so that if he plays with the ignition, no power is supplied.
Go to the full post
8 replies to this topic
#1 dasupersprint
dasupersprint
  • 848 posts
Posted 19 March 2020 - 01:48 PM
Hello
Let me explain my situation. I have two kids, and the youngest really has the passion for the Mini. He likes to play in it all the time. With the indicators, the wipers, the heater fan, pretending to drive. That's fun and all, but now that the engine is in the car I will not let him play with the keys in the car in fear that he starts it.
I thought about disconnecting the starter wire each time but it would be time consuming. So my question is, is there some sort of switch I could put on the starter wire? That would be much easier to pop the bonnet, turn the switch, and there you go. Could be some sort of anti-theft device too.
And no, not letting him play is not an option
Edited by dasupersprint, 19 March 2020 - 02:45 PM.
#2 Chris1275gt
Chris1275gt
  • 1,050 posts
Posted 19 March 2020 - 02:00 PM
I fitted one of these interrupting the feed to the coil I fitted it to the lower shelf of the dash with the switch pointing downwards as a anti theft device.
https://www.minispar...|Back to search
Hello
And no, no letting him play is not an option
Hello
#3 Rorf
Rorf
  • 866 posts
Posted 19 March 2020 - 02:19 PM
1.  Remove the battery
2.  Lock the garage
#4 GraemeC
GraemeC
  • 7,473 posts
Posted 19 March 2020 - 02:26 PM
There are many isolator switches designed to work on heavy cables.
Personally I would look to fit something to the battery earth cable in the boot.:
An FIA style key switch:
http://www.minispare...px|Back to shop
or a 'Discarnect':
https://richbrook.co...-master-switch/
#5 DeadSquare
DeadSquare
  • 3,382 posts
Posted 19 March 2020 - 02:34 PM   Best Answer
#6 dasupersprint
dasupersprint
  • 848 posts
Posted 19 March 2020 - 02:43 PM
The white and red wire! You're right, it makes sense, the power will not be triggered to the other side of the solenoid.
Thanks for actually reading my question! I do not want to disconnect the battery like others suggested, or deny access to the Mini. He's already building childhood memories with that car.
Edited by dasupersprint, 19 March 2020 - 02:44 PM.
#7 DeadSquare
DeadSquare
  • 3,382 posts
Posted 19 March 2020 - 02:46 PM
You're welcome.
#8 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 19 March 2020 - 06:12 PM
Rig a switch in the white/red wire on the solenoid, fit it in a place you can get to easily but that means your son camt get to it (I know it isn't easy in a mini though)
#9 timmy850
timmy850
  • 3,605 posts
  • Local Club: MITG
Posted 20 March 2020 - 02:55 AM
I have a battery kill switch in the boot and just kill all the power every time I park overnight.
Before I did this the GPS fell off the windscreen and turned on the headlights...
