Vented Disc Problems
7 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 469 posts
  • Local Club: Whickham & DMC
Posted 21 March 2020 - 12:47 PM
My ‘65 Riley Elf which I am rebuilding, has been fitted with 8.4 vented discs and 4 pot calipers.
I am having problems with the calipers. The right hand one has a snapped bleed nipple, I have since snapped a second nipple, the third (top) one is OK. I am nervous about snapping an easy out inside the stuck nipple whilst trying to remove them.  I also need to remove the pistons to check & refurb these.
i realise  costs could escalate if I need to renew the pistons and am wondering what options I have with 8.4 vented discs.  The 4 pot calipers seem in short supply.
is there an alternative maybe 2 pot calipers that will fit the vented discs?
#2 nicklouse
  • 19,067 posts
Posted 21 March 2020 - 12:58 PM
Many calipers out there that are 4 pot and vented.
#3 Cooperman
  • 23,569 posts
Posted 21 March 2020 - 01:38 PM
I have a set of drilled and grooved 8.4" solid discs and pair of callipers you can have.
PM me if interested.
#4 DUF2
DUF2
  • 469 posts
Posted 21 March 2020 - 01:46 PM
I have the discs, they are in good nick.  It is the calipers that are a bit suspect. One caliper has 2 snapped bleed nipples, I suspect the pistons may require replacing, so was thinking I’d be better with new calipers.
I’m not convinced 4 pot calipers are necessary and was wondering if there is a suitable 2 pot caliper the will fit the Metro hub and 8.4 vented discs.
#5 absx2
absx2
  • 961 posts
Posted 21 March 2020 - 02:25 PM
In that case having the Metro hubs you just need to get yourself a set of bog standard Mini disc assembly's and bolt them on.
They are cheap as chips and more than adequate for the job unlike the metro hubs that will give bump steer and long pedal travel and apart from bragging rights vented discs add nothing to a road car and stay away from EBC pads and fit AP.
#6 Spider
  • 15,878 posts
Posted 21 March 2020 - 05:50 PM
A few ways you could go here. The cast 4 spot calipers do have a reputation for breaking nipples.
Mini Spares have an Alloy 4 Spot, that you would need a spacer kit for to fit on vented discs and have sensible 3/8" bleed nipples and are single circuit, so a tidier installation. I have these on a few cars and they are brilliant.
At the other end of the spectrum, it may well be cheaper and still end up with good brakes, to go to non-vented discs and cast 2 spot calipers.
Or you could have your repaired, but that could be costly to the point where the alloy calipers might be a better way forward.
#7 DeadSquare
DeadSquare
  • 3,382 posts
Posted 21 March 2020 - 06:04 PM
Perhaps this is the place to  mention:-
Always wrap a bit of PTFE tape round the threads of brake nipples and rear brake adjusters.
#8 Cooperman
  • 23,569 posts
Posted 21 March 2020 - 07:57 PM
If doing a brake change on a 65 Elf one might consider 7.5" discs, then original dia 10" wheels would fit.
