Rear Valance Weight Reduction
6 replies to this topic
#1 Tonylamb
Tonylamb
  • 360 posts
Posted 22 March 2020 - 09:09 AM
I've been over the topics and can't find anything specific to this. I really like the look of the rear valances with large holes. I presume this is done to save weight. I don't see that it saves much weight but I think it just looks great. Pic attached. I'm wondering if you can buy a valance like this or more importantly if you can cut the holes whilst the valance is in position? Has anyone done that. In the pic the edges of the holes look bent over and tidied? Can anyone help me with advice as to how to achieve this look?
#2 MacGyver
MacGyver
  • 1,028 posts
Posted 22 March 2020 - 09:16 AM
I believe the hole are made with dimple dies, doable in situ but as the valance is curved it might take a bit of panel work.
Painting will be inevitable.
On a second note, apart from weight loss, it also reduces air resistance. Not that you will notice it much.
Ben
Edited by MacGyver, 22 March 2020 - 09:17 AM.
#3 unburntfuelinthemorning
  • 2,003 posts
Posted 22 March 2020 - 12:34 PM
Holes in the valance are fine if you like that look however if this article from Mini Tech News is correct then don't expect a reduction in drag but rather a massive increase.
#4 Tonylamb
Tonylamb
  • 360 posts
Posted 22 March 2020 - 10:37 PM
thanks for that its actually really good reading. As I said I just like the look I'm not that bothered about drag or weight as the car isn't a racer just a fast roader.
#5 unburntfuelinthemorning
  • 2,003 posts
Posted 22 March 2020 - 10:47 PM
Simplyminis did it on the A panel, check it out.  They'd be the person to ask.
#6 KTS
KTS
  • 2,490 posts
Posted 22 March 2020 - 10:57 PM
..as MacGyver points out, the valance is curved so normal dimple dies won't work.
you could try and get dies made up to match the curvature of the panel, but i'd imagine that would be quite expensive....
Edited by KTS, 22 March 2020 - 10:57 PM.
#7 MacGyver
MacGyver
  • 1,028 posts
Posted 23 March 2020 - 08:12 AM
I believe he's also the 'valance guy' ?
