Unidentified Component
Best Answer nicklouse , 22 March 2020 - 11:18 PM
most likely put on the dash by a PO and never fitted. as said it is HALF of an end of the engine steady bush.
Yeah the bush looks too new, looks like probably the original engine steady bar in the car. And how the bush would have fallen out, let alone made its way into the cabin is perplexing
like i said the PO never fitted it.
Go to the full post
12 replies to this topic
#1 dunkyb
dunkyb
  • 85 posts
Posted 22 March 2020 - 05:31 PM
Hi,
Does anyone know what the attached piece is? It fell onto me today from around the steering column!
Little rubber piece, only a few cm tall, with inscription
‘British made - Bernard Jones Eng’
Thanks!
Edited by dunkyb, 22 March 2020 - 05:35 PM.
#2 dunkyb
dunkyb
  • 85 posts
Posted 22 March 2020 - 05:37 PM
#3 Quinlan minor
Quinlan minor
  • 1,382 posts
Posted 22 March 2020 - 05:57 PM
Bernard Jones Engineering ENGINE STEADY HEAVY DUTY BUSH
http://www.minimine....ush-single.html
Though what it was doing near the steering column is beyond me.
#4 dunkyb
dunkyb
  • 85 posts
Posted 22 March 2020 - 10:05 PM
Where should it be? Engine steady kinda sounds important :-S
#5 nicklouse
  • 19,062 posts
Posted 22 March 2020 - 10:31 PM
#6 dunkyb
dunkyb
  • 85 posts
Posted 22 March 2020 - 10:39 PM
Today I was trying to replace the engine earth strap (see pic)
Unsuccessfully.. couldn’t get the bolt off. I wonder if this is somehow related ...
#7 dunkyb
dunkyb
  • 85 posts
Posted 22 March 2020 - 11:11 PM
#8 nicklouse
  • 19,062 posts
Posted 22 March 2020 - 11:18 PM   Best Answer
#9 dunkyb
dunkyb
  • 85 posts
Posted 31 March 2020 - 06:43 PM
Had another unidentified red lead with a 25A fuse connecting down to the starter motor,
which I tracked to a dodgy looking and not working cigarette lighter.
I’ve removed it, but it was connected to this pin on the starter (solenoid?)
Should anything else be connected to this pin?
#10 dunkyb
dunkyb
  • 85 posts
Posted 31 March 2020 - 06:45 PM
Another image
Sorry I can’t figure out why images I upload from my phone to this forum are 90 degrees rotated!
Edited by dunkyb, 31 March 2020 - 06:46 PM.
#11 Ethel
  • 26,799 posts
Posted 31 March 2020 - 09:25 PM
Looks normal, even if the photo is like one of those "everyday items from unusual angles" photo competitions.
As the Mini's battery is in the boot, the solenoid screw post that attaches to the other end of the battery cable make a useful place to distribute the +12v from. Hence all those thick brown wires.
#12 dunkyb
dunkyb
  • 85 posts
Posted 01 April 2020 - 08:18 AM
Thanks Ethel. The cig lighter wasn’t actually getting a 12V feed from where it was plugged in as it wasn’t working
before I removed it. But could be a faulty unit. They just ran that red cable from the solenoid straight through the bulkhead.
#13 dunkyb
dunkyb
  • 85 posts
Posted 01 April 2020 - 08:51 AM
Just to add that the red cigarette lighter cable was connected to a little spade connector, not part of the main 12V wiring block where all the other thick brown wires connect to!
