Knocking Sound
13 replies to this topic
#1 bajean
bajean
  • Just Joined
  • 125 posts
  • Local Club: Malta Mini Owners Club
Posted 22 March 2020 - 07:30 PM
Hope everyone is well, today i decided to go on a solo drive with my mini, and as soon as i went to pull of there was a knocking sound or even the a panel makes when its warping coming from the engine bay and pedal area. It does this sound when pulling away both first and reverse, also when going at a certain low speed ( 10km/h approx ) and even when braking ( once again at low speed). I jacked the car up to do a spanner check but everything was tight except the subframe mounts, which i also nipped up. I honestly don't know what the sound is, and being only 20 i dont have a lot of experience. Any ideas ?
#2 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 22 March 2020 - 07:43 PM
Lift the carpet and check the floor where the subframe mounts bolt to it.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 22 March 2020 - 08:40 PM
Check the engine steadies.
#4 bajean
bajean
  • Just Joined
  • 125 posts
Posted 23 March 2020 - 10:22 AM
At the moment i dont have any carpet in the car, so i can see everything. Everything looks good, but when i hear this sound i also feel something in the heelboard. I did also check the engine steadies both top and bottom and they are both tight as well as having new poly bushes inside.
#5 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 23 March 2020 - 11:50 AM
Has it got rubber or solid subframe mounts?
I'd suggest carefully checking the front subframe rear mounts.
#6 andyapanel
andyapanel
  • 651 posts
Posted 23 March 2020 - 12:36 PM
+1 for the engine steady bushes
#7 Its a min
Its a min
  • 284 posts
Posted 23 March 2020 - 01:19 PM
Have you checked it's not something to do with the exhaust? Could be one of the mounts or even the manifold to gearbox bracket.
#8 Chris1275gt
Chris1275gt
  • 1,053 posts
Posted 23 March 2020 - 03:32 PM
I know you say it's from the front but I'd also check the battery is strapped down.
#9 bajean
bajean
  • Just Joined
  • 125 posts
Posted 24 March 2020 - 08:13 PM
The front subframe has both ends solid mounted. I just checked the exhaust and everything seems to be in order as well. And the battery is also strapped down. I honestly don't have any idea what it might be as I've checked half the car now ?
#10 Algordo1100
Algordo1100
  • 774 posts
Posted 24 March 2020 - 10:22 PM
Shock absorber bushes?
#11 MacGyver
MacGyver
  • 1,028 posts
Posted 25 March 2020 - 07:00 AM
Loose wheel...
Something loose under the wing?...
Quite difficult without hearing it.
#12 bajean
bajean
  • Just Joined
  • 125 posts
Posted 01 April 2020 - 11:37 AM
So after many frustrating hours thinking about what it could be, it turns out that when i swapped in the 1275 and was assembling everything i forgot u torque down the front right hub nut ?.
#13 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 01 April 2020 - 02:24 PM
So after many frustrating hours thinking about what it could be, it turns out that when i swapped in the 1275 and was assembling everything i forgot u torque down the front right hub nut .
Not the first time something like that has happened.
Glad you got to the bottom of it.
#14 bajean
bajean
  • Just Joined
  • 125 posts
Posted 18 July 2020 - 02:12 PM
So the sound is back again after a couple of months ! I immediately went back home and jacked the car up, and upon looking and moving the driveshaft it seems like there is a bit of play in both driveshafts. Is it normal to have some play or are they meant to be rock solid. The symptoms are exactly the same as before ( when accelerating from a stop or hard acceleration ).
