Storing My Sprite
5 replies to this topic
#1 mpain94
mpain94
  • 45 posts
  • Local Club: LSMOC
Posted 24 March 2020 - 04:58 PM
Hi everyone,
My 1995 Sprite is out of action with need for a new gearbox and has been for a while, hope to get it sorted this summer! Its been in a garage for months already. Currently the situation is:
-Battery Neg disconnected
-Not much fuel in (never added anything to it)
-Oil and filter done before it went away
-No cover on
-Not idling the car
Im sure there are things I should have done before putting it away but is there anything I should be doing in particular or can do now to keep everything as good as possible. I will put in Dehumidifier bags in asap.
Thanks!
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 24 March 2020 - 05:08 PM
Remove the plugs and give the bores a squirt of WD40.
Plug the plug holes with cloth.
Rotate the engine 90 degrees, using the fan / fan belt each week.
connect the battery to  a battery conditioner / charger.
Put bags of Mice poison in the car.
#3 Ethel
  • 26,822 posts
Posted 24 March 2020 - 05:12 PM
Keep the battery charged if you don' want to buy another. You could also put put it on stands to lift the tyres off the floor or a least give it the occasional shove to rotate the wheels. That'd be easier if you avoid using the handbrake.
#4 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 24 March 2020 - 07:06 PM
Does the cooling system have fresh coolant and is it the correct mix, as in not just straight water?
#5 mpain94
mpain94
  • 45 posts
  • Local Club: LSMOC
Posted 24 March 2020 - 07:59 PM
Is not fresh really and has been topped up with water over time. Drain it?
#6 DeadSquare
DeadSquare
  • 3,382 posts
Posted 24 March 2020 - 08:54 PM
Yes.
Then flush it well and refill with a strong glycol solution.
