Just Thinking Out Loud Here. Changing Stroke Length....
9 replies to this topic
#1 nicklouse
  • 19,063 posts
Posted 24 March 2020 - 11:17 PM
If you shorten the stroke for a given piston diameter you reduce the CR.
mmm who does shorter stroke cranks now? As I am allowed to go to less than 1300cc
#2 1968andyf
1968andyf
  • 147 posts
Posted 24 March 2020 - 11:54 PM
73.5mm bore 76mm stroke gives 1299cc both med and swiftune do steel cranks probably not cheap though, might need 970 rods as well
#3 GraemeC
GraemeC
  • 7,474 posts
Posted 25 March 2020 - 07:11 AM
You could use a 12G2827 SA crank which is about a 70mm stroke but 1.75” big ends so can be offset ground.
#4 mini13
mini13
  • 3,811 posts
Posted 25 March 2020 - 12:08 PM
okay, is there some more background here?
race reg? why is the CR important?
#5 nicklouse
  • 19,063 posts
Posted 25 March 2020 - 10:32 PM
Just thinking out loud. If the block will not take a hone. And the head can not have CCs added then bore it and short stroke it.
out here the limit is 1300cc so 1299 is perfect.
and if I am spending 3.5k on crank  rods and pistons anyway......
#6 Spider
  • 15,865 posts
Posted 26 March 2020 - 12:06 AM
Reducing the Stroke will reduce the CR, however, increasing the Bore - on paper - will increase the CR.
In both cases, it depends on the Pin height and also the Crown Shape.
#7 DeadSquare
DeadSquare
  • 3,382 posts
Posted 26 March 2020 - 09:16 AM
The (just over 76mm) 3" stroke 2" mains 998 engine nearly happened. (it could have used an A.H. Sprite Mk4 block),
For about two years there was a pile of un-machined forgings in a scrap yard in Wolverhampton, and here is the sad part, they had that EN 40 tell-tale S 'ring' to them.
#8 mini13
mini13
  • 3,811 posts
Posted 26 March 2020 - 10:17 AM
Fair enough,
also if you cant take meat out of the head, its relativly easy to pop the pistons on a lath and take the dish out, unless youve got an odd dish ( v wedge, valve cutouts etc)
#9 nicklouse
  • 19,063 posts
Posted 26 March 2020 - 12:00 PM
Fair enough,
current S pistons had 8cc new forged Omegas will have 6cc
so I am just running ideas through
other option is to re-liner it. and work the pistons if possible.
#10 mini13
mini13
  • 3,811 posts
Posted 26 March 2020 - 04:09 PM
Liners is another good option.
I did see a pic of a KAD engine on facebook, and it looked to have oversize liners in ( not the normal ones, over oversize) it looked like it might be able to take a big bore 73-73.5, rather than the normal linered +20-+40
