Mpi Won`t Start
Best Answer Quinlan minor , 25 March 2020 - 02:27 PM
New battery in the fob and then press multiple times.
Go to the full post
6 replies to this topic
#1 71bay
71bay
  • 62 posts
Posted 25 March 2020 - 10:28 AM
Hi, just put the battery back in after winter lay off, it`s been on a maintainance charge.
Turn key and nothing, think my immobaliser is not connecting with key ?
SRS light goes out on button but alarm light is on constant.
Any pointers would be a great help.
Cheers Martin.
#2 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 25 March 2020 - 11:02 AM
My MPi's starter functioned even when the alarm/immobiliser was activated and, indeed, it would start and run for a few seconds before dying from lack of fuel pressure. So it's unlikely to be that.
Do you have a voltmeter on the dash?
Can you clarify what you mean by "SRS light goes out on button"?
SRS light should come on when the ignition key is first put in the 'On' position, while it runs through its self-test and then goes out, if test is successful.
Have you tried turning on the headlights and turning the key to 'Start'? Do the lights remain on, dim or go out?
Edited by Quinlan minor, 25 March 2020 - 11:40 AM.
#3 71bay
71bay
  • 62 posts
Posted 25 March 2020 - 02:13 PM
Hi thanks for the reply.
Volt meter on dash shows 12V
Electrics work fine its as if the immobiliser isnt reacting when pressing the fob.
#4 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 25 March 2020 - 02:27 PM   Best Answer
#5 71bay
71bay
  • 62 posts
Posted 25 March 2020 - 02:48 PM
I will give it a go, thanks
#6 71bay
71bay
  • 62 posts
Posted 25 March 2020 - 02:56 PM
Thanks,yes that was all it was DOH !
#7 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 25 March 2020 - 02:59 PM
Glad to help.
These things are often easier to see, when looked at from the outside.
