My main beam nor flash is working, dipped and sides ok.
I have checked for power around the switch column. So there is purple live. And this switches fine between the blue wire for the flash and the blue/white wire for switched main beam.
Horn works, rear fog works.
I wasn't sure if the dip-dim relay affects main beam?.
Looking at the wiring diagrams I can't see any fuses after the wires come out of the stalk only before they go in.
Ed
Main Beam Not Working
Eds.mini.lulu
, Mar 28 2020 11:33 AM
Best Answer Eds.mini.lulu , 28 March 2020 - 02:14 PM
Bulbs where fine, have narrowed it down to needing a new wire to trigger the relay, so will order what I need. Consider solved Go to the full post
3 replies to this topic
Posted 28 March 2020 - 11:33 AM
Posted 28 March 2020 - 11:44 AM
Does the 'Main beam (blue) warning light', on the dash, light up?
If not, it may be the switch.
Posted 28 March 2020 - 12:17 PM
Have you checked the bulbs?
Posted 28 March 2020 - 02:14 PM Best Answer
