Ballast V None Ballast
10 replies to this topic
#1 cotty
cotty
  • Just Joined
  • 60 posts
Posted 29 March 2020 - 07:09 PM
how do you alter your ballast to none ballast
#2 nicklouse
  • 19,057 posts
Posted 29 March 2020 - 07:11 PM
Change the coil and remove/bypass the ballast wire.
#3 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 30 March 2020 - 06:55 PM
You need a 12v coil, a length of appropriate size wire to go along the wiring loom to the fuse box and 2 spade connectors
#4 cotty
cotty
  • Just Joined
  • 60 posts
Posted 09 April 2020 - 07:51 PM
where is the none ballast by pass located
#5 jonsharman
jonsharman
  • 71 posts
Posted 09 April 2020 - 08:19 PM
Take a new feed from spade one of your fuse box (where the white wire connects) and run to the +ve on your new coil.
Your ballast wire is white with a pink trace and you need to disconnect that from the coil. There will be a white yellow wire going from the coil to the starter and that needs to stay.
#6 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 09 April 2020 - 08:40 PM
The white yellow can also be ditched. Run a new feed from the fuse box and cut the ballast resistor out of its junction near the fuse box. Use some heat shrink to cover the cut wire, or remake the connections with a butt connector
#7 cotty
cotty
  • Just Joined
  • 60 posts
Posted 12 April 2020 - 08:37 AM
hi guys can you tell me what dose a ballast resistor  look like ? thanks
#8 jonsharman
jonsharman
  • 71 posts
Posted 12 April 2020 - 08:45 AM
What year is your car? It may be that the wire is a resistive wire rather than actually having a resistor fitted.
#9 cotty
cotty
  • Just Joined
  • 60 posts
Posted 12 April 2020 - 09:14 AM
mini mayfair 1992
#10 cotty
cotty
  • Just Joined
  • 60 posts
Posted 12 April 2020 - 09:25 AM
mayfair 1992
#11 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 12 April 2020 - 09:41 AM
A 1992 car shouldn't have a ballast resistor coil or wire.
Give your wires a clean and double check the colours
Edited by cal844, 12 April 2020 - 09:42 AM.
