Which Standard Ratio Rockers?
5 replies to this topic
#1 Superdeluxe
Superdeluxe
  • 34 posts
Posted 29 March 2020 - 08:41 PM
I'm using a mini spares evo001 cam and they recommend to use standard ratio rockers however the cylinder head will have double valve springs.
Can anyone recommend some standard ratio rockers to use with this combination? I assume anything that was standard fit might not be up to the job.
Rich
Edited by Superdeluxe, 29 March 2020 - 08:41 PM.
#2 nicklouse
  • 19,066 posts
Posted 29 March 2020 - 08:53 PM
Any. Take your pick. If the pressed steel ones you might want to put a bead of weld along the tops. Or you current ones will be fine.
#3 DeadSquare
DeadSquare
  • 3,382 posts
Posted 29 March 2020 - 08:58 PM
A series rockers are much stronger than they are often said to be.
#4 blacktulip
blacktulip
  • 6,231 posts
Posted 29 March 2020 - 09:04 PM
When I rebuilt my old engine I treated myself to the cooper s spec A series rockers from minispares. Very nice and very in keeping.
#5 Spider
  • 15,873 posts
Posted 29 March 2020 - 09:06 PM
Even in the standard Rockers, there was 3 Ratios !
Pressed ones give the highest Ratio.
#6 Superdeluxe
Superdeluxe
  • 34 posts
Posted 30 March 2020 - 04:06 AM
Cheers for the advice. Will just re-use the originals
