I have removed the old fuel filter and yes it was a pain so I have had to order an new pipe from the tank and adaptor along with the filter and a new inertia switch just in case. I will report on the results when I receive the parts, although the current unpleasantness seems to have slowed down the parts pipeline. thanks again.
Spi Engine Cuts Out Randomly
Best Answer Jilksy , 14 April 2020 - 12:35 PM
The fuel filter and inertia switch are now changed and it seems to have done the trick so a big thank you to all. In my quest to fix the problem I also changed the plugs and plug leads. when the old plugs came out one of them was definately not correct as it had half the thread length as the rest and so was operating in a little tunnel so the wee thing is now running much more sweetly.
Go to the full post#16
Posted 04 April 2020 - 03:11 PM
#17
Posted 06 April 2020 - 08:16 AM
Thanks for that advice Humph, I've got the standard parts on order but i will change to your system when it needs changing in two year's time.
#18
Posted 14 April 2020 - 12:35 PM Best Answer
#19
Posted 15 April 2020 - 04:52 PM
Also ECU automatically resets if you disconnect battery and leave for an hour or so. Resets to original factory settings and then when you next start, relearns.
This is not true. You need a diagnostic unit to reset the ECU which is why that functionality was built into Testbook and others
FS
#20
Posted 15 April 2020 - 11:25 PM
Edited by Squipper, 15 April 2020 - 11:49 PM.
#21
Posted 15 April 2020 - 11:33 PM
FS
FS
Your not resetting the ECU. The ECU goes back to ZERO and then learns as if its running a new engine, if that makes sense?
Is absolutely true, if you disconnect battery and leave a while then reconnect will absolutely!!!! Done it myself and by specialist Mini garage, get your info right I'm afraid matey
Edited by Squipper, 15 April 2020 - 11:48 PM.
#22
Posted 16 April 2020 - 01:24 PM
FS
FS
what setting goes back to zero then?
#23
Posted 16 April 2020 - 05:37 PM
FS
FS
ECU factory setting, when you dis connect the re connect the battery, the ECU sets up as if the engine has never been run, it then re learns, resets, and adjusts running as it then gets the sensor readings, if that makes sense
#24
Posted 17 April 2020 - 04:01 PM
And you have verified this by what method?
#25
Posted 29 April 2020 - 02:56 PM
Done after getting air leak in breather hose by me and by Mini Garage after changing steering wheel, also two weeks ago when Mini Garage fitted KN Filter and LCB. On all occasions the battery was dis connected, then as I then drove Mini, the car ran better and better as ECU re learned the new parameters.
#26
Posted 29 April 2020 - 05:46 PM
Weather the ECU was reset or not surly the car would run better as the ECU learns the new parameters after any repair or modification.
#27
Posted 30 April 2020 - 09:32 AM
