Mpi Revs Hang For A Second Or Two
44 replies to this topic
#31 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 04 May 2020 - 07:52 AM
have you looked in the ACR section to see if anyone in/near your area has a unit they can lend / help with checking and resetting.
I have just got one but:-
a) up in Bucks
b) no idea how to drive it .!! [yet]
atb Jon
P.S. it'll be really good if/when Pscan gets this added, I think he'd sell a lot more if he did.
Edited by g0myw, 04 May 2020 - 07:53 AM.
#32 pete l
pete l
  • 1,533 posts
Posted 04 May 2020 - 09:26 AM
You have a new throttle body, It needs to be set up correctly, they are not setup when they leave the factory because every car breathes differently.
#33 nickowen
nickowen
  • 25 posts
  • Local Club: Looking for one
Posted 12 May 2020 - 02:45 PM
Please could you tell me how you set up the throttle body ?
#34 FlyingScot
FlyingScot
  • 2,676 posts
Posted 12 May 2020 - 04:05 PM
Normal situation is to check the basics. Throttle cable set, linkages operate smoothly no air leaks.
On ACR you ensure car is at operating temperature and perform service reset - which forces ECU to relearn ( disconnecting the battery doesn’t do this).
Then stepper set up where the ACR takes control of the engine and cycles through revving up and dropping down to idle.
on some versions of the software this has a graphic showing the level of opening of the IACV.
My experience in doing this was after the service reset on a club members MPi the revs shot up to over 1500 then MEMS took control and it dropped back.
As far as I know only Testbook/T4, Sykes Pickavant ACR and Crypton ACT diagnostics have this type of functionality and from memory Crypton ACT was only SPi not MPi. Of course main difference is SPi stepper opens the throttle butterfly and the “stepper” in MPi is the Inlet Air Control Valve which is a separate element which is bolted on.
FS
#35 nickowen
nickowen
  • 25 posts
Posted 13 May 2020 - 04:15 AM
Thanks FlyingScot, that makes sense. I have asked Pscan if they can add this functionality into their equipment and I will see if I can borrow an arc4 etc, local to me.
#36 pete l
pete l
  • 1,533 posts
Posted 13 May 2020 - 07:37 AM
Here's a list of people that have a T4. Look through it, there might be one near you.
https://the75andztcl...ad.php?t=201841
#37 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 13 May 2020 - 10:04 AM
Hi Nick,
I have posted my acr4 to PScan so that he can investigate this very option, and add it to the PScan suite of functions.
Fingers crossed this will be possible.
#38 nickowen
nickowen
  • 25 posts
Posted 14 May 2020 - 05:57 AM
Thanks for your help everyone.
i hope Pscan can add this to the software.
#39 nickowen
nickowen
  • 25 posts
Posted 27 May 2020 - 08:20 PM
Gents,
Pscan have now added this software and it has enabled to solve the issue.
:proud:
#40 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 28 May 2020 - 08:28 AM
Hi Nick ,
I am going to give this a go on ours later.
Any tips or observations for me.?
I see the Windows version is available - I use linux so hope that is now done
https://www.the-t-ba...re-version-042a
atb Jon
#41 nickowen
nickowen
  • 25 posts
Posted 28 May 2020 - 12:18 PM
Hi Jon,
I do not really have any tips, it was just a case of playing with the idle adjustment screw until it cured my issue. My stepper was originally set at about 26 steps, but no I have set it to 42 steps and it is faultless. I have the Burlen 52mm throttle body that was supposedly set up out of the factory, but like already stated earlier in this thread, each car and set up is unique.
The benefit is that I had the confidence to do this, knowing that I could return it to the original stepper position if all went wrong.
The Pscan kit is now superb.
Please let me know how you get on.
Many thanks
Nick
#42 tmsmini
tmsmini
  • 760 posts
  • Local Club: MOASF
Posted 28 May 2020 - 04:00 PM
Just following some of the posts on the PScan site, I see screen shots indicating oil temperature. While the MEM2J has the capability for an oil temp sensor, on an MPi Mini, the sensor feeds the gauge directly.
There are a number of features of the MEMS2J not used in an MPi mini, but probably used in other applications.
As long as it gets to the point where it allows adjustment, it should not be an issue.
I would be curious what your MAP reading is now.
Terry
#43 pete l
pete l
  • 1,533 posts
Posted 29 May 2020 - 08:36 AM
The MEMS2J was used in the early MGFs.
#44 nickowen
nickowen
  • 25 posts
Posted 29 May 2020 - 09:19 AM
My map reading is between 46 and 48 on idle.
Is this ok ?
#45 tmsmini
tmsmini
  • 760 posts
  • Local Club: MOASF
Posted 29 May 2020 - 05:24 PM
I can't answer that for sure.
The data embedded in the ACR says:
Strategy manifold pressure in kPA, expect 100 kPA Key on and 30 kPA at fast idle
When I had the 52 mm TB installed, I also got higher readings.
With the 48 mm TB now installed, I still get higher readings, but I also have an LCB exhaust, a modified inlet and a modified head.
